DCNM webinterface login issue with https
Forest Worstell
Visitor
We are having trouble logging into the webinterface of our new DCNM installation.
(Cisco Prime DCNM 6.2(3), Windows 2008 R2 SP1 64  bit version, US)
DCNM seems to be working fine so far, except for the login to the webinterface.
When calling https://<SERVER_IP> (we are using the default 443 and 8443 ports), the login page appears.
Entering the credentials results in the following message popups:
"Failed to pass the Authentication."
"Session is disconnected."
"Navigation could not be retrieved!"
We are running TACACS and the FM server log shows the user credential passes it.  But then it shows:
[[localhost].[/]] action: UIIController request was not authenticated. Ending Struts processing.
[[localhost].[/]] action: UIIAuthenticateImple returned response to the client.
2013.08.15 09:13:33  INFO  [fms.session] session close: session: 20, local client: <DCNM_IP>, user: <USER>@TACACS, role: network-
admin, loginTime: Thu Aug 15 09:13:21 CDT 2013, lastAccessTime: Thu Aug 15 09:13:21 CDT 2013
WHAT AM I MISSING HERE???
AM I LOOKING IN THE WRONG PLACE???
Below is a sampling from the fmserver log.
2013.08.15 09:13:21  INFO  [fms.security] aaa.server.primary = <TACACS1_IP>, Port = 49, method = pap
2013.08.15 09:13:21  INFO  [fms.security] Authenticating <USER> on <TACACS1_IP> is succeeded.
2013.08.15 09:13:21  INFO  [fms.security] aaa.server.primary = <TACACS2_IP>, Port = 49, method = pap
2013.08.15 09:13:21  INFO  [fms.security] Authenticating <USER> on <TACACS2_IP> is succeeded.
2013.08.15 09:13:21  INFO  [fms.session] new session: session: 20, local client: <DCNM_IP>, user: <USER>@TACACS, role: network-admin,
2013.08.15 09:13:22  INFO  [fms.model] loaded all groups
2013.08.15 09:13:22  INFO  [[localhost].[/]] action: UIIController request was not authenticated. Ending Struts processing.
2013.08.15 09:13:22  INFO  [[localhost].[/]] action: UIIAuthenticateImple returned response to the client.
2013.08.15 09:13:33  INFO  [fms.session] session close: session: 20, local client: <DCNM_IP>, user: <USER>@TACACS, role: network-admin,
thaywood
Community Member
Did you find a solution ?
