Decommission switch in fabric
billnewton
I have a MDS 9148 running in legacy mode interop mode 2 with a Brocade 4100. It's been working great and all zones are synchronized. I see the Brocade is listed as the principle switch.
I now want to decommission the Brocade, do I need to make the MDS the principle switch first? What's the best way to safely remove the Brocade from the fabric, just disconnect and wipe? For the MDS can I just switch back to native mode using "no vsan <#> interop 2"?
maminhas
-if there are only 2 switches in fabric. and you remove the one switch(brocade). the other switch shall automatically become principle switch.
else you can check what is the current priority of the switch.
9148# show fcdomain
VSAN 1
The local switch is the Principal Switch.
Local switch run time information:
        State: Stable
        Local switch WWN:    20:01:00:0d:ec:2c:54:c1
        Running fabric name: 20:01:00:0d:ec:2c:54:c1
        Running priority: 128 <<<<<<<<<
        Current domain ID: 0x11(17)
Local switch configuration information:
        State: Enabled
        FCID persistence: Enabled
        Auto-reconfiguration: Disabled
        Contiguous-allocation: Disabled
        Configured fabric name: 20:01:00:05:30:00:28:df
        Optimize Mode: Disabled
        Configured priority: 128  <<<<<<<<
        Configured domain ID: 0x00(0) (preferred)
lower the number , higer the priority.
To manually lower the number to make it principle switch:
http://www.cisco.com/en/US/docs/storage/san_switches/mds9000/sw/rel_3_x/configuration/guides/cli_3_3/domn.html#wp1113148
if you want to change the interop mode of a vsan.
the command is
