Dell Equallogic SAN Design
Thomas Yarger
All,
I have six Dell Equallogic SANs connected to two Cisco 3750X (Stacked) in a redundant fashion. I have enabled Jumbo Frames (9000) and I configured a Port-Channel connecting back to the Distribution Layer. Keep in mind, our SAN and Server traffic reside in the same VLAN. Our Virtualization Platform is Citrix / Xenserver. I'm currently seeing many Output Drops on the 3750X connecting the SANs. I believe the buffers are almost full. Any thoughts? Possible design recommendations?
Public buffer pools:
Small buffers, 104 bytes (total 50, permanent 50, peak 119 @ 1w2d):
     49 in free list (20 min, 150 max allowed)
     29870278 hits, 23 misses, 69 trims, 69 created
     0 failures (0 no memory)
Middle buffers, 600 bytes (total 25, permanent 25, peak 85 @ 1w2d):
     23 in free list (10 min, 150 max allowed)
     292659 hits, 39 misses, 117 trims, 117 created
Big buffers, 1536 bytes (total 50, permanent 50, peak 260 @ 1w2d):
     50 in free list (5 min, 150 max allowed)
     7118336 hits, 87 misses, 261 trims, 261 created
VeryBig buffers, 4520 bytes (total 16, permanent 10, peak 16 @ 1w2d):
     0 in free list (0 min, 100 max allowed)
     59 hits, 3 misses, 6 trims, 12 created
Large buffers, 5024 bytes (total 0, permanent 0):
     0 in free list (0 min, 10 max allowed)
     0 hits, 0 misses, 0 trims, 0 created
Huge buffers, 18024 bytes (total 4, permanent 0, peak 7 @ 1w2d):
     4 in free list (0 min, 4 max allowed)
     325240 hits, 13959 misses, 27855 trims, 27859 created
Interface buffer pools:
RxQFB buffers, 2040 bytes (total 904, permanent 904):
     896 in free list (0 min, 904 max allowed)
     1676806 hits, 0 misses
RxQ0 buffers, 2040 bytes (total 1200, permanent 1200):
     700 in free list (0 min, 1200 max allowed)
     12989722 hits, 0 misses
RxQ1 buffers, 2040 bytes (total 128, permanent 128):
     5 in free list (0 min, 128 max allowed)
     18683526 hits, 766906 fallbacks
RxQ2 buffers, 2040 bytes (total 128, permanent 128):
     1 in free list (0 min, 128 max allowed)
     809774 hits, 6326 fallbacks, 0 trims, 0 created
     6326 failures (0 no memory)
RxQ3 buffers, 2040 bytes (total 128, permanent 128):
     6272522 hits, 51299 fallbacks
RxQ4 buffers, 2040 bytes (total 128, permanent 128):
     0 in free list (0 min, 128 max allowed)
     761106 hits, 906039 misses
RxQ5 buffers, 2040 bytes (total 128, permanent 128):
     64 in free list (0 min, 128 max allowed)
     64 hits, 0 misses
RxQ6 buffers, 2040 bytes (total 128, permanent 128):
     128 hits, 0 misses
RxQ7 buffers, 2040 bytes (total 192, permanent 192):
     61 in free list (0 min, 192 max allowed)
     513149 hits, 0 misses
RxQ8 buffers, 2040 bytes (total 64, permanent 64):
     0 in free list (0 min, 64 max allowed)
     3405180 hits, 3390852 misses
RxQ9 buffers, 2040 bytes (total 1, permanent 1):
     0 in free list (0 min, 1 max allowed)
     1 hits, 0 misses
RxQ10 buffers, 2040 bytes (total 64, permanent 64):
     1 in free list (0 min, 64 max allowed)
     5460093 hits, 822752 fallbacks
RxQ11 buffers, 2040 bytes (total 16, permanent 16):
     0 in free list (0 min, 16 max allowed)
     16 hits, 0 misses
RxQ12 buffers, 2040 bytes (total 96, permanent 96):
     0 in free list (0 min, 96 max allowed)
     96 hits, 0 misses
RxQ13 buffers, 2040 bytes (total 16, permanent 16):
     16 hits, 0 misses
RxQ15 buffers, 2040 bytes (total 4, permanent 4):
     0 in free list (0 min, 4 max allowed)
     16195688 hits, 16195685 misses
IPC buffers, 2048 bytes (total 300, permanent 300):
     290 in free list (150 min, 500 max allowed)
     822814 hits, 0 fallbacks, 0 trims, 0 created
Jumbo buffers, 9240 bytes (total 200, permanent 200):
     200 in free list (0 min, 200 max allowed)
     0 hits, 0 misses
Header pools:
5 Replies 5
Bill CARTER
Level 5
Level 5
Can you post the configuration? Enable flow-control. I also like the global command "buffer tune automatic"
http://www.cisco.com/en/US/docs/ios/netmgmt/command/reference/nm_02.html#wp1181763
How big of an impact will "buffer tune automatic"make? I will have to upgrade my 3750X so I can use that command. I do have flow-control enabled on the switchports. Is it necessary to enable flow-control on the uplink connections going to the Distribution Layer? Thanks
I think configuring flow-control on the uplinks would also help. Although I am not positive this is needed. I think the buffer tune automatic is worth it. Before upgrading you could try increasing "huge buffers max allowed". Start with 8.
I assume you're talking about adjusting the Huge Buffers pool? If not, I don't see the command "huge buffers max allowed" globally or under the interfaces. I'm on IOS 122-55.SE3. Thanks for your help!
The command is "buffers huge max-free #".
After readying this some more, it may be better to adjust the hold-queue on the interface. Can you post a show interface for a port experiencing output drops?
