device-alias import fcalias question
olmy
I had a quick question re: importing fcaliases into the device-alias database.
We have a series of zones that were previously configured using the fcalias for the member definition.
After the successful import of fcaliases into the device-alias database, should we expect to see the running config for each zone definition get updated to using the device-alias? Or, alternately, should the newly create device-alias only get used on a go-forward basis for future zones?
The 9500 is running 3.1(2a) and we have the switch configured to device-alias mode enhanced.
any guidance or info is appreciated.
thanks.
ivillegas
Level 6
Level 6
I think the newly created device alias will only get used on a go forward basis. Following link may help you
http://www.cisco.com/en/US/partner/products/ps5989/products_configuration_guide_chapter09186a008049b86f.html#wp1139948
