Disableing parts of callhome profiles
brucekreis
How do I configure a 9509 to send callhome info by full or short text only? I do not want any XML messages to be sent. Cant remove some of the alert groups and cant send anything without an XML destination email configured? Thnaks
plowden
You ought to be able to remove the email address in the XML destination profile and add it in the full text or short text destination profile (or both).
CLI commands:
sh callhome destination-profile
[note the line after "email addresses configured:" for XML destination profile; also note the line after "alert groups configured:" for full-txt or short-txt or both]
conf t
callhome
no destination-profile XML-destination email-addr X <-- email address from above
destination-profile short-txt-destination email-addr Y <-- add email if needed
no destination-profile short-txt-destination alert-group All <-- or whatever one(s) you want to delete
destination-profile short-txt-destination alert-group ? <-- list available groups
destination-profile short-txt-destination alert-group Inventory <-- add whatever you want
end
callhome test
You can also from the Device Manager (Admin/Events/Call Home.
When I remove the destination_profile email address, and all the other info for the XML profile, I get this message "IP address:callhome:warning:no callhome was sent (err_id 0x403B0011)"
XML destination profile looks like this:
or from command line:
MDS1A# callhome test
trying to send test callhome message
2004 Oct 13 09:39:44 MDS1A %CALLHOME-2-EVENT: Test
warning:no callhome message sent
XML destination profile information
maximum message size:0
message format:XML
message-level:0
upon further investigation, it appears that the three default destination groups cannot be de-configured and must have an email destination assigned for ALL three default destination groups before a test email will be sent. In addition, if you configure a new destination profile, in addition to the default three, it too must have an email destination configured or no alerts will be sent from any destination profile.
Still the only alert being sent is the XML version, no full or short text is being sent... can figure out why..
thanks,
