05-09-2012 07:43 AM
Dear All ,
I have a MDS 9216 connected to an MDS 9124 . The connected ports are showing as E Ports and not TE ports .
What do I need to do to get them in TE mode of operation .
MDS 9126 fc1/2 --------------------- fc 1/3 MDS 9124
MDS9216# sh int fc 1/2
fc1/2 is up
Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN)
Port WWN is 20:02:00:0d:ec:0c:78:00
Peer port WWN is 20:03:00:0d:ec:57:cd:00
Admin port mode is auto, trunk mode is auto
Port mode is E, FCID is 0x9a0001
Port vsan is 1
Speed is 2 Gbps
Transmit B2B Credit is 16
Receive B2B Credit is 255
Receive data field Size is 2112
Beacon is turned off
5 minutes input rate 144 bits/sec, 18 bytes/sec, 0 frames/sec
5 minutes output rate 272 bits/sec, 34 bytes/sec, 0 frames/sec
7751 frames input, 384692 bytes
0 discards, 0 errors
0 CRC, 0 unknown class
0 too long, 0 too short
7737 frames output, 596996 bytes
0 input OLS, 1 LRR, 0 NOS, 16 loop inits
3 output OLS, 3 LRR, 0 NOS, 4 loop inits
255 receive B2B credit remaining
16 transmit B2B credit remaining
Software
BIOS: version 1.1.0
loader: version 1.2(2)
kickstart: version 2.1(1b)
system: version 2.1(1b)
MDS9124# sh int fc 1/3
fc1/3 is up
Port WWN is 20:03:00:0d:ec:57:cd:00
Peer port WWN is 20:02:00:0d:ec:0c:78:00
snmp link state traps are enabled
Port mode is E
Port vsan is 1
Speed is 2 Gbps
Rate mode is dedicated
Transmit B2B Credit is 255
Receive B2B Credit is 16
5 minutes input rate 296 bits/sec, 37 bytes/sec, 0 frames/sec
5 minutes output rate 120 bits/sec, 15 bytes/sec, 0 frames/sec
8921 frames input, 732652 bytes
8930 frames output, 421396 bytes
5 input OLS, 6 LRR, 0 NOS, 8 loop inits
5 output OLS, 2 LRR, 4 NOS, 5 loop inits
16 receive B2B credit remaining
255 transmit B2B credit remaining
254 low priority transmit B2B credit remaining
Interface last changed at Wed May 9 03:32:24 2012
Software
BIOS: version 1.0.12
kickstart: version 3.2(3)
system: version 3.2(3)
Regards ,
Vikas Srivastava
Solved! Go to Solution.
05-09-2012 08:56 AM
both the sides are default to trunk mode auto. In this case there will be no trunking, just regular ISL.
Check Table 12-2
Can you configure one side to 'switchport trunk mode on' under the FC port and check if you can get the link up as TE port?
Thanks, Vin.
05-09-2012 08:16 AM
ie is this a new install or you have more vsans defined on the mds switches which you have allowed on the trunk ? what does the trunk config look like ?
from both switches, please get,
show vsan
show run int fc1/2(3)
Thanks, Vin.
05-09-2012 08:37 AM
Hi Vin ,
Heres the output :
Please note that on both the interfaces i have used the commands "switchport trunk allowed vsan all" but its not showing in the output here .
ICE-MDS9124# sh running-config int fc 1/3
version 3.2(3)
interface fc1/3
port-license acquire
ICE-MDS9216# sh run int fc 1/2
version 2.1(1b)
interface fc1/2
no shutdown
ICE-MDS9216# sh vsan
vsan 1 information
name:VSAN0001 state:active
interoperability mode:default
loadbalancing:src-id/dst-id/oxid
operational state:up
vsan 500 information
name:VSAN0500 state:active
vsan 600 information
name:VSAN0600 state:active
vsan 4094:isolated_vsan
ICE-MDS9124# sh vsan
vsan 1 information
05-09-2012 08:56 AM
Check Table 12-2
Thanks, Vin.
05-09-2012 09:19 AM
Thanks Vin , Configuring 'switchport trunk mode on' got as I wanted it to be ...
