Cisco 7000k fcoe card
henry.benjamin
Hi All
Anyone have the cisco 7000 fcoe card working, tac cannot help me new bug apparently
NXos-5.2(4)
Cisco ucs 1.4(3l)
cannot start services is the error ?
Licenses are installed on the root vdc and enabled for the module in slot 9
appreciate if anyone has any experience with this card.
cheers
Henry
6 Replies 6
Carlo Schmidt
Hi Henry,
Can you provide some more info on the issue? What are you configuring when you see this error?
Thanks!
Carlo
Following the guide however the fcoe service will not start in the storage vdc
see error below
Default_VDC_SW01-FCOE_SAN_NETAPP#  [34D [J
Default_VDC_SW01-FCOE_SAN_NETAPP# sh vlan fcoe
Service not enabled
Service not enabled
Service not enabled
Have you installed the feature-set fcoe in the default vdc?
After doing this, the feature-set needs to be installed in the fcoe vdc.
Let me know if this worked. If not, you might have to include a bit more on your current config.
Hi Carlo,
installed the feature yes, but apparenely if you create the stoarge vdc first this breaks the install ?
Cheers
Henry
logs below
feature       feature-set
Default_VDC_SW01# sh feature-set
Feature Set Name      ID        State
fcoe                   1          installed
fabricpath             2          uninstalled
fex                    3          uninstalled
mpls                   4          uninstalled
Default_VDC_SW01#
I would have to test this, not 100%. Can you include a 'show vdc' and a 'show feature-set' <-- from fcoe vdc
There are couple of bugs which we might be hitting, CSCty88696 and CSCtl66888. we are working on getting the release note populated for these issues as they are new issues which we have found wrt N7k FCoE.
Vin.
