Enable FSCP feature failed
MENG YUAN HSIEH
Hi experts,
We are try to enable fcsp feature. But console show "ERROR: service not found". What's problem is?
Best regards,
Meng-Yuan Hsieh (Nick)
24 Replies 24
Walter Dey
Hi Nick
Most likely the hardware you have doesn't support this feature !
Walter.
Our device is MDS9250i. We can found FC-SP in data sheet.
Is this a new license that you installed on this 9250i ?
If yes, I would open a TAC case
What is the output of
switch# show license brief
switch# show license usage ENTERPRISE_PKG
Hi Meng
Strange ! did you install the license ?
switch# install license bootflash:license_file.lic
Installing license ..done
Is license problem?
Q. Do I understand you correctly: you want Cisco TrustSec FC Link Encryption ?
If yes
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/sw/6_2/configuration/guides/security/nx-os/sec_cli_6-x/fctrstsec.html
The following modules are supported for the Cisco TrustSec FC Link Encryption feature:
    2/4/8/10/16 Gbps 48-ports Advanced Fibre Channel module (DS-X9448-768K9)
    32-port 8-Gbps Advanced Fibre Channel Switching module (DS-X9232-256K9)
    48-port 8-Gbps Advanced Fibre Channel Switching module (DS-X9248-256K9)
    1/2/4/8 Gbps 24-Port Fibre Channel switching module (DS-X9224-96K9)
    1/2/4/8 Gbps 48-Port Fibre Channel switching module (DS-X9248-96K9)
    1/2/4/8 Gbps 4/44-Port Fibre Channel switching module (DS-X9248-48K9)
    2/4/8/10/16 Gbps 96-ports Fibre Channel Switching Module (DS-C9396S-K9)
The Cisco MDS 9250i supports hardware-based IPsec encryption for secure transmission of sensitive data over extended
distances. Hardware enablement of IPsec helps ensure high throughput. Used together, hardware-based compression
and hardware-based encryption provide high-performance, highly secure SAN extension capabilities.
Comprehensive IPsec protocol suite delivers secure authentication, data integrity, and hardware-based encryption for
both FCIP and iSCSI deployments.
eg. MDS 9700 supports FC link encryption, I think the 9250i doesn't, which would explain your issue.
https://www.hds.com/assets/pdf/cisco-mds-9700-48-port-fibre-channel-switching-module-datasheet.pdf
Cisco TrustSec®Fibre Channel link encryption,
But datasheet show as below:
To verify that the "Enterprise License" is properly installed, enable e.g. feature ivr, which requires this license as well.
switch(config)# feature ivr
This means Enterprise license is ok !
Which SAN-OS version ? It must be quite actual, 9250i is a newer platform.
I would simply open a TAC case !
Walter.
Can you please do the CLI
(config)#feature ?
Sorry for reply late.
Looks like licensing is perfect !
Must be a trivial problem (or a very tricky one).
Do you see an error message in the log file ? (show logging log)
enable debugging (debug all) and check if (feature fcsp) gives you more error information.
