Enable FSCP feature failed
MENG YUAN HSIEH
Hi experts,
We are try to enable fcsp feature. But console show "ERROR: service not found". What's problem is?
Best regards,
Meng-Yuan Hsieh (Nick)
24 Replies 24
In "show logging log" I did not found any error about SCSP. But there are some error in the "show tech". However I still did not have any idea...
I see that your date / time is totally off: Mon Jun 19 11:54:12 2000
Can you please correct this.
Clock have corrected. But fuction still can not enable.
did you install
kickstart: m9250-s5ek9-kickstart-mz.6.2.13b.bin
nxos: m9250-s5ek9-mz.6.2.13b.bin
and it is still not working ??
The switch is running No payload encryption (NPE) images NX-OS.
show version
  kickstart image file is: bootflash:///m9250-s5ek9-kickstart-mz-npe.6.2.7.bin
  system image file is:    bootflash:///m9250-s5ek9-mz-npe.6.2.7.bin
Can you install the regular NX-OS?
David
Hi David,
I found the newest software in Cisco website as below. Is it right?
kickstart: m9250-s5ek9-kickstart-mz.6.2.9c.bin
nxos: m9250-s5ek9-mz.6.2.9c.bin
Yes !!
Hi Nick,
Our sorting algorithm is sub-optimal.  I'd go with 6.2(13b).
6.2(9c)
6.2(9b)
6.2(9a)
6.2(9)
6.2(7)
6.2(5a)
6.2(5)
6.2(13b)
6.2(13a)
6.2(13)
6.2(11d)
6.2(11c)
6.2(11b)
6.2(11)
Hi Meng
To verify that the "Enterprise License" is properly installed, enable e.g. feature ivr, which requires this license as well.
If this works, please read my next reply !
switch(config)# feature ivr
Our device is MDS9250i. We can found FC-SP in data sheet.
