ESCON
hosui.tse
A or B on the connector is the Tx?
mrfrase
I don't know what A - B are in accord with Tx - Rx , but tx is usually on the right. You can also enable the port and see which has light , that's transmitt.
mrfrase,
Thank you. I dont have a power meter and actually I am preparing a panel for connecting ST to ESCON connectors. BTW, the A and B are marked on the ESCON Connector.
Possibbly your answer can be found in the IBM Redbooks at:
http://publib-b.boulder.ibm.com/Redbooks.nsf/redbooks/
