ESX 5 + Cisco Nexus 2000 Series Fabric Extenders
don.lynch
I have connected one of 4 NIC's on an ESX Hypervisor 5 Server to the nexus 2000 above.
The Nic reports that it is down but when I connect the nic to another switch it works fine.
A laptop connected to the nexus works fine.
I'd appreciate it if someone could offer a suggestion as to whether the is aditional/specific configuration tasks required on the nexus to get the esx nic working?
Don
padramas
Hello Don,
Can you please provide the switchport configuration and following ESXi command output
esxcfg-nics -l
esxcfg-vswitch -l
Padma
I'm on version 5 so the commands are different but here is the info requested -
vSwitch info
vSwitch0
   Class: etherswitch
   Num Ports: 128
   Used Ports: 7
   Configured Ports: 128
   MTU: 1500
   CDP Status: listen
   Beacon Enabled: false
   Beacon Interval: 1
   Beacon Threshold: 3
   Beacon Required By:
   Uplinks: vmnic0
   Portgroups: VM Network, Management Network
vSwitch1
   Class: etherswitch
   Num Ports: 128
   Used Ports: 9
   MTU: 1500
   CDP Status: listen
   Beacon Interval: 1
   Beacon Threshold: 3
   Beacon Required By:
   Uplinks: vmnic2
   Portgroups: Servers
vSwitch2
   Class: etherswitch
   Num Ports: 128
   Used Ports: 2
   MTU: 1500
   CDP Status: listen
   Beacon Interval: 1
   Beacon Threshold: 3
   Beacon Required By:
   Uplinks: vmnic3
   Portgroups: Back Network
vSwitch3
   Class: etherswitch
   Num Ports: 128
   Used Ports: 2
   MTU: 1500
   CDP Status: listen
   Beacon Interval: 1
   Beacon Threshold: 3
   Beacon Required By:
   Uplinks: vmnic1
   Portgroups: Windows Network
and
Nic info
Name   PCI Device     Driver Link Speed Duplex MAC Address         MTU Description
vmnic0 0000:001:00.0 bnx2   Up     1000 Full   00:25:64:fd:3e:b7 1500 Broadcom Corporation Broadcom NetXtreme II BCM5709 1000Base-T
vmnic1 0000:001:00.1 bnx2   Down     0 Half   00:25:64:fd:3e:b9 1500 Broadcom Corporation Broadcom NetXtreme II BCM5709 1000Base-T
vmnic2 0000:002:00.0 bnx2   Up     1000 Full   00:25:64:fd:3e:bb 1500 Broadcom Corporation Broadcom NetXtreme II BCM5709 1000Base-T
vmnic3 0000:002:00.1 bnx2   Up     1000 Full   00:25:64:fd:3e:bd 1500 Broadcom Corporation Broadcom NetXtreme II BCM5709 1000Base-T
It's vmnic1 and vSwitch3 that are on the nexus and not responding.
Don
Hi Don,
Have you tried manually setting the nic's speed/duplex?
Can you post a "show fex detail", "show int ethX/X/X", "sh run int ethX/X/X" for the affected port?
Message was edited by: Brian Morrissey
