ethernet functionality after enabling NPV on FI
farid nasiri
Community Member
on attached scenario the FI is NPV enabled to be able to pass flogi to upstream core brocade san switches
the question is does enabling npv affects negatively FI's functionality on Ethernet processing ?
later 2* C3750 switch will add to the scenario which logically should be connected to FIs
Walter Dey
No ! FC and Ethernet are totally independent ! Use Ethernet also in EHM
Walter Dey
