Fabric manager not able to manage new 9124e switches
blueyonderguy
Fabric manager not able to manage new 9124e switches. It is able to discover fabric using seed switches (9513) but all 9124e appear with Timeout (server,client) error. logs show that communication times out. Even if I try to select the switch and "reauthenticate", it throws timeout error.
I have added FM server's IP in SNMP configuration of host using following.
snmp-server host <IP> traps version 2c public
both are running 4.2.3 code. I am able to connect to the switches using SSH from the FM server and there is no firewall in between either.
Any pointers?
Kris Vandecruys
Hello Blue Yonder,
Since the switches are new it might be that they are shipping with new OUIs which certain versions of FabricManager don't recognize.  A simple upgrade of FM will fix this issue.
More details can be found here: http://www.cisco.com/en/US/ts/fn/633/fn63302.html
HTH,
Kris
Kris Vandecruys
Hello Blue Yonder,
HTH,
Kris
thanks Kris ..had exact same problem. Upgraded FM to 4.2.3a , deleted fabric and re-discovered and and voila ..Timeout error is gone.
Thanks a bunch
@dynamoxxx
thanks a ton...that worked
upgrade to 4.2.3a did not work for me however. had to upgrade to version 5
