02-20-2014 01:00 PM
I have a Dell host that has a couple FC cards in it. I have plugged the Dell FC cards directly into the Cisco FI's and would like to configure the zoning to the EMC SAN that is also directly connected to the Cisco FI's. Is there a way to configure the zoning directly on the FI to allow the Dell WWPN's to see the EMC SAN? I have all the UCS blades zoned appropriately and it is working, but I need to know if the Dell servers can work the same way or if I need to connect them to the Nexus 5Ks and configure the zoning on them.
Solved! Go to Solution.
02-21-2014 04:50 AM
Hi Kevin
This is not supported, see https://supportforums.cisco.com/thread/2268117?tstart=0
Connect your Dell servers to the Nexus 5k instead !
There is however a caveat: If I understand you correctly, your storage (EMC) is directly connected to UCS FI ? Therefore you created VSAN's which has zoning managed by UCSM.
If you have a Northbound N5K, which is connected with classical FC to the UCSM FI, it is mandatory not sharing the same VSAN as used above. Therefore you would need to create a separate VSAN, and zoning would be done on the N5k, and also pushed back to the UCS FI.
Although this technically works and has been done multiple times, it is not officially TAC supported. Maybe someone from the TAC can clarify.
Walter.
02-21-2014 04:50 AM
Hi Kevin
Walter.
02-21-2014 07:26 PM
you can zone directly on the FI
@dynamoxxx
02-22-2014 12:08 AM
the question was not: can you do zone directly on the FI, but can you do zone directly on the FI with DELL SERVERS !!
Yes, for UCS managed servers (by means of a service profile) , be it blade or rack mount, and direct attached storage !
NOT POSSIBLE / SUPPORTED FOR NON CISCO SERVERS
02-22-2014 09:59 AM
sorry missed that. I am glad you edited your initial post.
@dynamoxxx
03-04-2014 10:38 AM
wdey - thanks for that quick response and sorry for not getting back to this post sooner. One more quick question, I would assume that the 5K's will need to have the ports licensed for FC connectivity? I originally installed/configured them with just standard licensing and seem to recall that FC connectivity is a separate license per port.
Thanks again!
03-04-2014 12:24 PM
Hi Kevin
Yes, to use native FC and/or FCoE ports, you need a storage license
Storage Protocols Services Package FC_FEATURES_PKG | N5010-SSK9 N5020-SSK9 N55-8P-SSK9 N55-48P-SSK9 N55-96P-SSK9 |
