12-13-2004 10:39 AM
Folks,
Can i tie more than 1 FCIP tunnel to a Gigabit ethernet interface. I was reading documentation and if i remeber correctly, it mentioned about support for upto 3 tunnels over a gigabit ethernet interface, not sure if i can attach more than 1 FCIP tunnel to a gigabit ethernet interface.
12-13-2004 04:32 PM
Yes, you can run 3 FCIP logical tunnels over a physical GigE interface.
02-05-2005 04:31 AM
If you dont use 802.1q (vlan):
You must create another fcip interface and use existing fcip profile, but when configuring peer-info
address you should use another ip address.
fcip profile 1
ip addres 1.1.1.1
exit
int fcip 1
use profile 1
peer-info ipaddress 1.1.1.2
int fcip 1
use profile 1
peer-info ipaddress 1.1.1.3
