how remove fc port from vsan nexus ??
mehdimes
hi
when i want  remove  fc  port from vsan i see this  messgae in cli  and cant remove fc  port from vsan ???
N5k-1(config-vsan-db)# no vsan 263 interface fc 4/4
'no' option is not supported with this command
anybody know how to remove fc port   from vsan  in nexus5500 ????
Walter Dey
Each interface has to be in exactly one VSAN; by default, all interfaces are in VSAN 1; therefore just move your interface in VSAN 1; and I hope, that you don't use VSAN 1 for production !
Walter Dey
thank you ,solved with your reply
