How to Capture Fiber Channel traffic
dtran
Level 6
Level 6
Hi all,
I have a few Brocade switches and I am looking for a tool that does packet capture for fiber channel traffic, similar to Wireshark for IP traffic. Has anyone used one or recommend one ? or Can Wireshark capture and decode fiber channel traffic ?
Thanks in advance !!
Danny
Justin Welch
Usually a capturing tool such as Xgig is used. However, I encourage you to look at the following posts as well:
http://community.brocade.com/t5/Fibre-Channel-SAN/Sniffing-Fibre-Channel-Packets-from-Brocade-Switch-200E/td-p/21680
https://ask.wireshark.org/questions/27036/capturing-fibre-channel-frames
Hope this helps,
Justin
Thanks Justin !!! I also found this link. Looks like a FC analyzer is needed.
http://www.eagletek.com.tw/eng/products.php?item=1&itemid=118
Danny
