How to enable GigabitEthernet flow between SN5420 and Sun Adapter ?
admin_2
Level 3
Level 3
When Solaris is using a Sun Gigabit Ethernet
Adapter to connect to an SN5420, GigabitEthernet flow
control must be enabled to ensure maximum SN5420
performance. Versions: SN5420 and 1.8x iSCSI driver
Not applicable
By default, receive flow control is disabled for the Sun Gigabit
Ethernet Adapter (i.e. it does not send pause frames).
To enable flow control:
(1) add the following line to /kernel/drv/ge.conf (this file does not
exist by default): adv_pauseTX=1;
(2) Reboot Solaris.
(3) Verify adv_pauseTX is set properly with the following cmd: ndd /dev/ge
adv_pauseTX (it should respond with a value of 1).
Flow control (pause frames) must also be enable in the GbE switch.
They are disabled by default in the Cisco 6500
hogutier
Useful information for Sun Gigagit Ethernet adapters:
http://www.cisco.com/warp/customer/741/5.html
