How to interpret the RMON Alerts
Chetan R
Hello
Following alerts are being received via e-mail
EventId, Id Time Description
4.47 2011/11/15-08:46:01 1.3.6.1.4.1.9.9.289.1.2.1.1.38.17362944=0 <= 0:65500, 4 WARNING(4)Falling
From the above i can understand that this is related to "fcIfTxWtAvgBBCreditTransitionToZero > 1.3.6.1.4.1.9.9.289.1.2.1.1.38"
However i would want to know to which port/interface is the above alert referring to.
fcIfTxWtAvgBBCreditTransitionToZero OBJECT-TYPE
  SYNTAX          Counter64
  MAX-ACCESS      read-only
  STATUS          current
    DESCRIPTION    "The number of times average buffer-to-buffer credits at an FC-port has transitioned to zero"
   ::= { fcIfErrorEntry 38 }
Attached are the RMON alerts
Please advise
maminhas
The way to interperate which perticular interface it is,
in this thread , take the last octect   "17362944"
convert it to hex number
which is 108f000
and run the command on the switch
switch# show port internal info interface-id 0x108f000  (i,e with prefix 0x)
that would tell you what is the physical interface it belongs to.
maminhas
which is 108f000
