How to manage Nexus5010
aotholland
Hi experts,
I have an issue.
I tried configure nexus 5010 via console. But I just can not.
I use putty, but it is nothing to be seen on console. I can not see how it is booted. I've changed the speed but also not helped.
Status and power leds are green. Do you have any idea what i can do?
Thanks.
franjime
Check to make sure the pinouts on the console cable are what you are expecting?
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/hw/installation/guide/portcabl.pdf
Table C-1 lists the pinout for the cable that is needed.
