How to manually send snmp traps from Cisco MDS SAN Switches
anand.gopinath1
Hi Team
We are busy integrating our Cisco MDS SAN Switches ( fw 6.2(3) )  with BPPM .
For this we need to send snmp traps to BPPM server .
Is there a way we can manually send traps  ( as a test  ) from the Cisco MDS cli  ??
Appreciate your quick response in this regard
Anand
Walter Dey
Hi Anand
Have a look at
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/sw/5_0/configuration/guides/sysmgnt/nxos/sysmgmt_cli/snmp.html
Walter.
jihicks
Hi Anand,
This will send a trap to the configured trap destination(s):
switch# test pfm snmp test-trap ?
  fan          Generate a test SNMP Trap for fan
  powersupply  Generate a test SNMP Trap for PowerSupply
  temp_sensor  Generate a test SNMP Trap for Temperature
Best regards,
Jim
Real dumb question how can i unsend the trap the  switch still thinks it has a bad powers supply
test pfm snmp test-trapPowerSupply
no test pfm snmp test-trapPowerSupply does not work
