06-20-2012 12:00 AM
We recently started using the cisco nexus 5000 switch.
Previosuly we were using brocade switch.
In order to monitor the throughput on the switch ports, we used the command >perfportshow
output:
0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 Total
52m 0 0 79m 79m 52m 0 0 0 0 0 0 0 0 0 0 262m
It used to depict the throughput on each of its 16 ports.
Do we have a similar command on a cisco nexus 5000 swithc to monitor the throughput dynamically on the ports.
Any guidance appreciated.
Thanks.
06-20-2012 02:06 AM
On 9509 switches I use " sh int counters brief module *" * for the number of each Module in this case 2 and I get the following output.
sh int counters brief module 2
Interface Input (rate is 5 min avg) Output (rate is 5 min avg)
Rate Total Rate Total
MB/s Frames MB/s Frames
fc2/1 0 1 0 1
fc2/2 0 1224699488 0 3429684064
fc2/3 0 1 0 1
fc2/4 0 1214147374 0 1927673039
fc2/5 0 1 0 1
fc2/6 0 1 0 1
fc2/7 0 1 0 1
fc2/8 1 11510254385 11 19770450459
fc2/9 18 58026366094 44 220233153527
fc2/10 19 17008767450 19 35833527274
fc2/11 0 39851510969 0 156730340768
fc2/12 0 1 0 1
fc2/13 0 1 0 1
fc2/14 0 3543781575 0 16305763606
fc2/15 0 1 0 1
fc2/16 0 1 0 1
fc2/17 0 1 0 1
fc2/18 0 1 0 1
fc2/19 0 1 0 1
fc2/20 0 1 0 1
fc2/21 0 1 0 1
fc2/22 0 1 0 1
fc2/23 0 1 0 1
fc2/24 0 32036382020 0 97783387882
fc2/25 0 30948988897 0 103928942588
fc2/26 0 1 0 1
fc2/27 0 9660166159 0 16594964293
fc2/28 0 1 0 1
fc2/29 0 8288591099 0 12351752310
fc2/30 0 3817420276 1 18060412406
fc2/31 0 8693113679 2 15227020605
fc2/32 2 18464865368 1 26363448965
fc2/33 0 1 0 1
fc2/34 0 1 0 1
fc2/35 0 1 0 1
fc2/36 0 1 0 1
fc2/37 0 1 0 1
fc2/38 0 1 0 1
fc2/39 0 1 0 1
fc2/40 0 1 0 1
fc2/41 0 359100865497 0 64890519049
fc2/42 0 1 0 1
fc2/43 0 310679253243 0 77398281413
fc2/44 0 1 0 1
fc2/45 3 27809296255 0 42985060915
fc2/46 0 15946062800 0 32744671193
fc2/47 1 27140980991 0 71032538176
fc2/48 0 23496252397 0 48801426244
06-20-2012 03:17 AM
Thanks Roy.
But is that dynamic.. ?
What i mean is - in the portperfshow command, it systematically displays the throughput on the ports and that too in real time with a interval of 1 second.
You just fire the command and sit back and you will get per second throughput stats.
does the above has same capabilities?
Thanks.
06-20-2012 04:07 AM
I know that Brocade command from many years ago, no it doesn't do the automatic refresh. You can also use " sh int aggregate-counters brief" for all the modules usage but that doesn't refresh either. I think you could script something to re-run either command every 5 minutes thou.
Cheers
06-20-2012 04:57 AM
You can try Device Mangaer summary tab.
It's #3 in this link.http://www.cisco.com/en/US/docs/switches/datacenter/mds9000/sw/5_2/configuration/guides/fund/DCNM-SAN-LAN_5_2/dm.html#wp254943
The poll interval might be 10 or 30 seconds. Select Util%.
David
04-24-2018 07:15 PM
After the port type has been changed from Ethernet to FC, the FC port will not be enabled on the switch until FCOE feature is enabled:
N5K(config)#feature FCOE
C license checked out successfully
fc_plugin extracted successfully
FC plugin loaded successfully
FCoE manager enabled successfully
FC enabled on all modules successfully
Enabled FCoE QoS policies successfully
