How to remote a zone form a zone set?
Brett.Lombardo1
Hello all
I'm relatively new to MDS zoning and putting my best foot forward on the googles but i've hit a snag.
I need to remove the following zone from a zoneset. Any input would be appreciated.
# show zoneset active
zoneset name vsan10_zs vsan 10
zone name V15010ESXIORC01_v1-VX7600-a4 vsan 10
* fcid 0x010000 [pwwn 50:06:01:64:36:e0:0c:e6]
pwwn 20:00:00:25:b5:01:a0:19
#show zonetset
fcalias name VX7600-a4 vsan 10
fcalias name V15010ESXIORC01_v0 vsan 10
zone name V15010ESXIORC01_v0-VX7600-b4 vsan 10
fcalias name VX7600-b4 vsan 10
pwwn 50:06:01:6c:36:e0:0c:e6
Thanks Brett
Please tell me again, which zone you would like to remove ?
V15010ESXIORC01_v1-VX7600-a4 ?
Due to the fact that you use enhanced zone mode, you should also add as last command
zone commit vsan 10
Please do after "zone commit vsan 10"
show running ...
and
show startup ...
Walter.
9 Replies 9
Walter Dey
Hi Brett
Conf t
no member V15010ESXIORC01_v1-VX7600-a4
zoneset activate name vsan10_zs vsan 10
Walter.
PS this procedure is non disruptive !
Hey Walter, thanks for the quick response, I keep getting this
# conf t
Enter configuration commands, one per line. End with CNTL/Z.
(config)# zoneset name vsan10_zs vsan 10
(config-zoneset)# no member V15010ESXIORC01_v1-VX7600-a4
Zone not present
Hi Brett
Please post the zone and zoneset information from the "show running" command !
Walter.
Does this help Walter? Excluded other items zoned.
!Command: show running-config zone
!Time: Thu Jul 21 00:57:10 2016
version 5.2(8e)
zone mode enhanced vsan 10
!Active Zone Database Section for vsan 10
member pwwn 50:06:01:64:36:e0:0c:e6
member pwwn 20:00:00:25:b5:01:a0:19
member pwwn 50:06:01:6c:36:e0:0c:e6
member V15010ESXIORC01_v0-VX7600-b4
do clear zone database vsan 10
!Full Zone Database Section for vsan 10
member fcalias VX7600-a4
member fcalias V15010ESXIORC01_v0
member fcalias VX7600-b4
zone commit vsan 10
Thanks Brett
zone commit vsan 10
show running ...
and
show startup ...
Walter.
Thanks again Walter, looks like that worked.
Am I running in to a similar issue here?
Somehow I put in the wrong member pwwn and have this. The bold needs to be removed:
zone name V15010ESXIORC01_v1-VX7600-a1 vsan 11
member pwwn 50:06:01:61:36:e0:0c:e6
member pwwn 20:00:00:25:b5:01:b1:19
member pwwn 20:00:00:25:b5:01:b1:18
zone name V15010ESXIORC01_v1-VX7600-b1 vsan 11
member pwwn 50:06:01:69:36:e0:0c:e6
So i ran
# conf t
(config)# zone name V15010ESXIORC01_v1-VX7600-a1 vsan 11
(config-zone)# no member pwwn 20:00:00:25:b5:01:b1:19
Member not present
...Sorry still new to this.
Sorry for the confusion !
A zoneset consists of zones
member V15010ESXIORC01_v1-VX7600-a4 <== zone
member V15010ESXIORC01_v0-VX7600-b4 <== zone
and a zone has members, eg. defined as a pwwn, device-alias or fc-alias
Now I understand that you want to remove members of a zone, and NOT a zone from a zoneset ?
correct ?
PS.
# conf t
should work, but you have to add
zone commit vsan 11
Sorry I forgot ! most important, once you have done your modifications (in memory), save the configuration:
conf t
copy run start
Thanks Walter, you are a life saver. I got it all worked out from the lines you supplied and understand it all now.
