HX managment subnet
Networker_eg
If I have 2 HX-Clusters sharing the same FI and uplink switches
Is it okey to share :
HX-mgmt vlan
HX-storage vlan
HX-replication vlan
between the 2 clusters or it is recommended to use different sub nets for each cluster
My concern is HX management interface uses the MC address 224.0.0.18 to advertise so if the 2 clusters use the same subnet the SCVM of both clusters will join ,
Clifford Aldan
It is ok to have both clusters using the same subnets
When each HX storage cluster is created, the storage controllers are assigned to a storage domain unique to each cluster
Thus, storage controllers from different storage domains will not join a cluster it's not assigned to
Keep the VLAN names different, but the VLAN ID can be the same
For example, a two 3-node cluster would look like this:
HX-1 VLANs
VLAN NAME: hx-1-mgmt
VLAN ID: 10
Subnet: 172.16.10.0/24
- hx-1-esxi-1: 172.16.10.101
- hx-1-esxi-2: 172.16.10.102
- hx-1-esxi-3: 172.16.10.103
- hx-1-scvm-1: 172.16.10.111
- hx-1-scvm-2: 172.16.10.112
- hx-1-scvm-3: 172.16.10.113
- hx-1-scvm-mgmt-ip: 172.16.10.120
VLAN NAME: hx-1-storage-data
VLAN ID: 20
Subnet: 172.16.20.0/24
- hx-1-esxi-1: 172.16.20.101
- hx-1-esxi-2: 172.16.20.102
- hx-1-esxi-3: 172.16.20.103
- hx-1-scvm-1: 172.16.20.111
- hx-1-scvm-2: 172.16.20.112
- hx-1-scvm-3: 172.16.20.113
- hx-1-scvm-data-mgmt-ip: 172.16.20.120
VLAN NAME: hx-1-vmotion
VLAND ID: 30
Subnet: 172.16.30.0/24
- hx-1-esxi-1: 172.16.30.101
- hx-1-esxi-2: 172.16.30.102
- hx-1-esxi-3: 172.16.30.103
VLAN NAME: hx-1-vm-network
VLAN ID: 40
Subnet: 172.16.40.0/24
HX-2 VLANs
VLAN NAME: hx-2-mgmt
VLAN ID: 10
- hx-2-esxi-1: 172.16.10.201
- hx-2-esxi-2: 172.16.10.202
- hx-2-esxi-3: 172.16.10.203
- hx-2-scvm-1: 172.16.10.211
- hx-2-scvm-2: 172.16.10.212
- hx-2-scvm-3: 172.16.10.213
- hx-2-scvm-mgmt-ip: 172.16.10.220
VLAN NAME: hx-2-storage-data
VLAN ID: 20
- hx-2-esxi-1: 172.16.20.201
- hx-2-esxi-2: 172.16.20.202
- hx-2-esxi-3: 172.16.20.203
- hx-2-scvm-1: 172.16.20.211
- hx-2-scvm-2: 172.16.20.212
- hx-2-scvm-3: 172.16.20.213
- hx-2-scvm-data-mgmt-ip: 172.16.20.220
VLAN NAME: hx-2-vmotion
VLAND ID: 30
- hx-2-esxi-1: 172.16.30.201
- hx-2-esxi-2: 172.16.30.202
- hx-2-esxi-3: 172.16.30.203
VLAN NAME: hx-2-vm-network
VLAN ID: 40
Clifford Aldan
HX-1 VLANs
VLAN ID: 10
VLAN ID: 20
VLAND ID: 30
VLAN ID: 40
HX-2 VLANs
VLAN ID: 10
VLAN ID: 20
VLAND ID: 30
VLAN ID: 40
Hi Clifford. Does this mean that I can ignore the warning that pops up for the VLAN for the storage network?
VLAN
Validating 'storage-data' VLAN: 'xxx' specified for new cluster is already assigned
This is the only warning that pops up during validation. Can I skip validation.
