WWN vs FCID
kwftide1
I understand WWNs are 64 bits and FCIDs are 24 bits and I understand the fabric assigns FCIDs when a device logs into the fabric (FLOGI).
Here's what seems confusing:
Since a device is communicating via FC and that protocol uses FCIDs, what is the purpose of a WWN? If devices (disregarding HP-UX and AIX) point to WWNs but the fabric uses FCIDs, where is this mapping stored on the server and how does it work exactly? Is there a table like a ARP cache? If so, when does it time out?
My point is, there is no field in the FCID frame for WWNs - only source and destination FCIDs. So, how do WWNs play into this picture?
6 Replies 6
tblancha
You can think of WWN's as MAC addresses and FCID as the layer3 IP address. So, the WWN is burned into the HBA firmware. HPUX and AIX take the FCID of the storage they are talking to and enter it into a persistent file on the /etc filesystem. The wwn to FCID mapping can be seen with show flogi database and show fcns database.
mrfrase
Also, the part of the operation of the HBA on the host is to store and retain a Login map of all targets, it stores both FCID's and PWWN's of devices on the SAN so it can build frames for commands that are sent to storage devices, FC devices learn PWWN of target port from PLOGI ACC , the 24 bit FCID is used to route frame through the SAN using FSPF, 24 bit lookup is much faster then 64 bit lookup, but remember access control to storage is many times controlled by PWWN, both for zoning on Switch and also the controller port on the array. This PWWN is checked at PLOGI for access control.
So, if the initiator HBA learns the target's FCID during PLOGI, how long is the FCID retained by the server? Is the FCID retained until a logout occurs or does it time out (like an arp entry)?
One reason I ask is I'd like to fully understand the ramifications of changing FCIDs.
Host learns target's fcid thro' Plogi into NameServer,if it is zoned together. It is retained
as long as storage is in the fabric with same fcid
and host has PLOGIed onto the storage.
FCID of storage is retained in the host until
LOGO (explicit).
If the storage is not in fabric, then RSCN
is generated and host requeries the name server
for the storage, if it is not there, then
HBA cleans up resources related to that FCID.
Thanks for all the replies!
H,
I am also having this confusion. I have a different post going on a Nexsus 9148 IOS upgrade. I am so new to this data center and VSAn work and configuring nexus. my back ground has always been routing and switching but I have been assign this task without having formal training or experience on this. I have been reading the whole day so far and getting closer however, i still need to know where i start on a nexus. For example: on this singe Nexus 9148 that will be used for two zones:
I have:
A xxxxx2vio1_ZoneA xxxxx2vio1 xxxxx2vio1_p1 10:00:00:00:c9:8c:8e:24
A xxxxxx2vio1_ZoneA xxxxx2vio1 svs9san05_a2 20:24:00:80:e5:18:9e:56
B xxxxxx3vio1_ZoneB xxxxxx3vio1 svs9san05_a1 20:14:00:80:e5:18:9e:56
B xxxxxxx3vio1_ZoneB xxxxxxx3vio1 svs9san05_b1 20:15:00:80:e5:18:9e:56
  vmhost-xxxxxx02_ZoneA vmhost-xxxxxx svs9san05_a2 20:24:00:80:e5:18:9e:56
vmhost-xxxxxx02_ZoneB vmhost-xxxxxx svs9san05_a1 20:14:00:80:e5:18:9e:56
vmhost-xxxxxxx02_ZoneB vmhost-xxxxxx-02 svs9san05_b1 20:15:00:80:e5:18:9e:56
vmhost-xxxxxxx02_ZoneB vmhost-xxxxxx-02 vmhost-xxxxxx02_p2 21:00:00:24:ff:29:e2:6b
I have edited the above table showing samples of each zone (about 6 lies of A and 6 lines of B with WWN numbers shown). so, what are those 28-bits numbers? are they defined as is or they are defined in the Switch? I have been told to use these same numbers.
so, any help to get me going will be appreciated. I have been reading on pwwn numbers and other variables/definitions/standards but I still do not know where to begin except for:
Command
Explanation
switch#conf t
Enters configuration terminal
switch(config)# zoneset name
Zoneset_10 vsan 10
Enters Zoneset configuration mode. Creates Zoneset_10 for vsan 10 if it
does not exist
switch(config-zoneset)# zone
name Host_A-Target_1
Enters in-line Zone configuration mode. Creates zone Host_A-Target_1 in
vsan 10 and as a member to Zoneset_10 if it does not exist
switch(config-zoneset-zone)#
member pwwn
21:01:00:e0:8b:39:a9:07
Add pwwn as a member of zone Host_A-Target_1
member pwwn
21:00:00:20:37:af:a5:93
zone commit vsan 10
Commits the changes made to the zones and zoneset in vsan 10. Used only
if enhanced zoning is enabled
switch(config)# zoneset activate
name Zoneset_10 vsan 10
Sets the active zoneset as the currently configured Zoneset_10 in vsan 10.
Note that only 1 zoneset can be active in a vsan at a time
switch(config)# zone commit
vsan 10
Commits the change made to the zoneset in vsan 10. This step is required
in enhanced zoning mode after an activation in order for the new activation
to occur
So, you think I may be able to pull this off using what is listed above and other commands sets that i have in document that I am going to use as my guide? Cisco document. i may be asking for to much but I do not have any other choice but to reach out.
single Cisco Nexus 9148 and two zones.
Best Regards,
Masood
