Hyperflex Replication Network Configuration
bezeddin
Level 4
Level 4
Folks,
I'm trying to configure Hyperflex replication network pair between cluster
replication network will be using different vlan on each cluster
let say site A using vlan 248 and site B using vlan 249 (both routable between cluster)
since replication vlan already add to UCSM and ESXI I chose existing vlan
but when adding IP range, error appear "Pre Replication Network Configuration validation failed. IP address: 10.1.248.14 is already in use. Please verify there are no duplicate IPs"
no matter which IP range used it always say the fourth IP is duplicate
for example If I start with 10.1.248.100 it will say 10.1.248.103 is duplicate
replication vlan is newly created and I can assure no device using the fourth IP
I really appreciate any insight regarding this issue
Budi
First, each cluster is set up for replication networking. Use HX Connect to provide a set of IP addresses to be used by local cluster nodes to replicate to the remote cluster. HX Connect creates VLANs through UCS Manager, for dedicated replication network use.
Please refer the link for more details:-
https://www.cisco.com/c/en/us/td/docs/hyperconverged_systems/HyperFlex_HX_DataPlatformSoftware/AdminGuide/3_0/b_HyperFlexSystems_AdministrationGuide_3_0/b_HyperFlexSystems_AdministrationGuide_3_0_chapter_01101.html
