Interface reset causes Port-channel to flap
Hi all,
I am having the issues explained below , I did not find any bug related to the below error messages , your help is appreciated.
Here is an example of what each switch logs when a server drops offline. Sample logs taken between 5:32am and 5:35am on Feb 20. This particular one was having problems all weekend. Switch #1 encountered over 2000 interface resets. The corresponding VPC port on Switch #2 only had 13 resets.
NEXUS SWITCH #1
2012 Feb 20 05:32:09 q91-sw01-5010 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel10: first operational port changed
from Ethernet1/10 to none
2012 Feb 20 05:32:09 q91-sw01-5010 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel10: Ethernet1/10 is down
2012 Feb 20 05:32:09 q91-sw01-5010 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel10: port-channel10 is down
2012 Feb 20 05:32:09 q91-sw01-5010 %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN: Interface port-channel10 is down (
No operational members)
2012 Feb 20 05:32:09 q91-sw01-5010 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/10 is down (Link failure)
2012 Feb 20 05:32:19 q91-sw01-5010 %ETHPORT-5-SPEED: Interface Ethernet1/10, operational speed changed to 10 Gbps
2012 Feb 20 05:32:19 q91-sw01-5010 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/10, operational duplex mode changed to
Full
2012 Feb 20 05:32:19 q91-sw01-5010 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/10, operational Receive Flow
Control state changed to off
2012 Feb 20 05:32:19 q91-sw01-5010 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/10, operational Transmit Flow
2012 Feb 20 05:32:19 q91-sw01-5010 %ETHPORT-5-SPEED: Interface port-channel10, operational speed changed to 10 Gbps
2012 Feb 20 05:32:19 q91-sw01-5010 %ETHPORT-5-IF_DUPLEX: Interface port-channel10, operational duplex mode changed
to Full
2012 Feb 20 05:32:19 q91-sw01-5010 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface port-channel10, operational Receive Flo
w Control state changed to off
2012 Feb 20 05:32:19 q91-sw01-5010 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface port-channel10, operational Transmit Fl
ow Control state changed to off
2012 Feb 20 05:32:20 q91-sw01-5010 %ETH_PORT_CHANNEL-5-PORT_UP: port-channel10: Ethernet1/10 is up
2012 Feb 20 05:32:20 q91-sw01-5010 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel10: first operational port changed
from none to Ethernet1/10
2012 Feb 20 05:32:20 q91-sw01-5010 %ETHPORT-5-IF_UP: Interface Ethernet1/10 is up in mode trunk
2012 Feb 20 05:32:20 q91-sw01-5010 %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 999 on Interface port-channel10 are b
eing suspended. (Reason: Vlan is not allowed on Peer-link)
2012 Feb 20 05:32:20 q91-sw01-5010 %ETHPORT-5-IF_UP: Interface port-channel10 is up in mode trunk
2012 Feb 20 05:33:22 q91-sw01-5010 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel10: first operational port changed
2012 Feb 20 05:33:22 q91-sw01-5010 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel10: Ethernet1/10 is down
2012 Feb 20 05:33:22 q91-sw01-5010 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel10: port-channel10 is down
2012 Feb 20 05:33:22 q91-sw01-5010 %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN: Interface port-channel10 is down (
2012 Feb 20 05:33:22 q91-sw01-5010 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/10 is down (Link failure)
2012 Feb 20 05:33:32 q91-sw01-5010 %ETHPORT-5-SPEED: Interface Ethernet1/10, operational speed changed to 10 Gbps
2012 Feb 20 05:33:32 q91-sw01-5010 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/10, operational duplex mode changed to
Full
2012 Feb 20 05:33:32 q91-sw01-5010 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/10, operational Receive Flow
2012 Feb 20 05:33:32 q91-sw01-5010 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/10, operational Transmit Flow
2012 Feb 20 05:33:32 q91-sw01-5010 %ETHPORT-5-SPEED: Interface port-channel10, operational speed changed to 10 Gbps
2012 Feb 20 05:33:32 q91-sw01-5010 %ETHPORT-5-IF_DUPLEX: Interface port-channel10, operational duplex mode changed
to Full
2012 Feb 20 05:33:32 q91-sw01-5010 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface port-channel10, operational Receive Flo
2012 Feb 20 05:33:32 q91-sw01-5010 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface port-channel10, operational Transmit Fl
2012 Feb 20 05:33:33 q91-sw01-5010 %ETH_PORT_CHANNEL-5-PORT_UP: port-channel10: Ethernet1/10 is up
2012 Feb 20 05:33:33 q91-sw01-5010 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel10: first operational port changed
2012 Feb 20 05:33:33 q91-sw01-5010 %ETHPORT-5-IF_UP: Interface Ethernet1/10 is up in mode trunk
2012 Feb 20 05:33:33 q91-sw01-5010 %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 999 on Interface port-channel10 are b
2012 Feb 20 05:33:33 q91-sw01-5010 %ETHPORT-5-IF_UP: Interface port-channel10 is up in mode trunk
2012 Feb 20 05:34:35 q91-sw01-5010 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel10: first operational port changed
2012 Feb 20 05:34:35 q91-sw01-5010 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel10: Ethernet1/10 is down
2012 Feb 20 05:34:35 q91-sw01-5010 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel10: port-channel10 is down
2012 Feb 20 05:34:35 q91-sw01-5010 %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN: Interface port-channel10 is down (
2012 Feb 20 05:34:35 q91-sw01-5010 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/10 is down (Link failure)
2012 Feb 20 05:34:46 q91-sw01-5010 %ETHPORT-5-SPEED: Interface Ethernet1/10, operational speed changed to 10 Gbps
2012 Feb 20 05:34:46 q91-sw01-5010 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/10, operational duplex mode changed to
Full
2012 Feb 20 05:34:46 q91-sw01-5010 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/10, operational Receive Flow
2012 Feb 20 05:34:46 q91-sw01-5010 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/10, operational Transmit Flow
2012 Feb 20 05:34:46 q91-sw01-5010 %ETHPORT-5-SPEED: Interface port-channel10, operational speed changed to 10 Gbps
2012 Feb 20 05:34:46 q91-sw01-5010 %ETHPORT-5-IF_DUPLEX: Interface port-channel10, operational duplex mode changed
to Full
2012 Feb 20 05:34:46 q91-sw01-5010 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface port-channel10, operational Receive Flo
2012 Feb 20 05:34:46 q91-sw01-5010 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface port-channel10, operational Transmit Fl
2012 Feb 20 05:34:46 q91-sw01-5010 %ETH_PORT_CHANNEL-5-PORT_UP: port-channel10: Ethernet1/10 is up
2012 Feb 20 05:34:46 q91-sw01-5010 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel10: first operational port changed
2012 Feb 20 05:34:46 q91-sw01-5010 %ETHPORT-5-IF_UP: Interface Ethernet1/10 is up in mode trunk
2012 Feb 20 05:34:46 q91-sw01-5010 %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 999 on Interface port-channel10 are b
2012 Feb 20 05:34:46 q91-sw01-5010 %ETHPORT-5-IF_UP: Interface port-channel10 is up in mode trunk
2012 Feb 20 05:35:48 q91-sw01-5010 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel10: first operational port changed
NEXUS SWITCH #2
2012 Feb 20 05:32:20 q91-sw02-5010 %ETHPORT-3-IF_ERROR_VLANS_REMOVED: VLANs 999 on Interface port-channel10 are rem
oved from suspended state.
2012 Feb 20 05:32:20 q91-sw02-5010 %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 999 on Interface port-channel10 are b
2012 Feb 20 05:33:33 q91-sw02-5010 %ETHPORT-3-IF_ERROR_VLANS_REMOVED: VLANs 999 on Interface port-channel10 are rem
2012 Feb 20 05:33:33 q91-sw02-5010 %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 999 on Interface port-channel10 are b
2012 Feb 20 05:34:46 q91-sw02-5010 %ETHPORT-3-IF_ERROR_VLANS_REMOVED: VLANs 999 on Interface port-channel10 are rem
2012 Feb 20 05:34:46 q91-sw02-5010 %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 999 on Interface port-channel10 are b
2012 Feb 20 05:35:59 q91-sw02-5010 %ETHPORT-3-IF_ERROR_VLANS_REMOVED: VLANs 999 on Interface port-channel10 are rem
2012 Feb 20 05:35:59 q91-sw02-5010 %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 999 on Interface port-channel10 are b
dchhaya
Hello Saleem.
  This looks like a physical layer problem
can you check the sfp on both sides adn the cable. can you also make sure if the server drivers are up to date. Can you connect the server to another port on the nexus and see if the same issue happens.
Thanks , I will test it and will let you know.
Saleem Roumaldaro
Service Consultant
Softchoice Corporation
Direct:905 847 6800 ext. 5334
Toll free: 888 436 5555
Fax: 905 847 6584
www.unislumin.com<../../../../../srei/Documents/2011/Edison/www.unislumin.com>
Test using TDR.
Command:
1.  test cable tdr interface ;
2.  Wait for about 60 seconds (because it's a Nexus); and
3.  sh cable tdr interface ; and
4.  Please post the result.
Link failure is most likely as it states a cable / SFP issue on the
remote side. (SFP failure on the local switch would tell you link not
connected or sfp not inserted).
