iSCSI
j.santayana
I'm testing iSCSI with SN5420 + Symetrix and clients iSCSI for UNIX and WIN NT. I'm trying to validate the use of this technologie with small bandwith. Has someone tested something similar??
I also have promblems during formating process from NT client, again, some clues??
Thanks in advance
ssoberlik
Level 4
Level 4
I found this useful URL on SN 5420 latency at: http://www.cisco.com/warp/public/cc/pd/rt/5420/prodlit/ltncy_br.htmI haven’t seen it run on less than a T1. What is the “small” bandwidth you’re using? If you are losing drive letters you need to save the boot information in the iSCSI driver window before you reboot. You’ll have to clear boot info if the configuration changes.
