Issues with 56128P FC Interfaces
Has anyone had issues with Cisco Nexus 56128P Chassis trying to convert interface type to FC
Please see below
PIH-DC-5K-SAN-B(config)# slot 1
PIH-DC-5K-SAN-B(config-slot)# port 33-48 type fc
ERROR: Module type doesn't support this CLI
PIH-DC-5K-SAN-B# show license usage
Feature Ins Lic Status Expiry Date Comments
Count
FCOE_NPV_PKG No - Unused -
FM_SERVER_PKG No - Unused -
ENTERPRISE_PKG No - In use Grace 119D 0H
FC_FEATURES_PKG No - In use Grace 113D 5H
VMFEX_FEATURE_PKG No - Unused -
ENHANCED_LAYER2_PKG Yes - Unused 14 Oct 2018 -
NETWORK_SERVICES_PKG No - Unused -
LAN_BASE_SERVICES_PKG Yes - In use never -
LAN_ENTERPRISE_SERVICES_PKG No - In use Grace 113D 6H
Kirk J
Greetings.
See https://www.cisco.com/c/en/us/products/collateral/switches/nexus-5000-series-switches/datasheet-c78-730760.html
Cisco Nexus 56128P Switch
The Cisco Nexus 56128P Switch (Figure 5) is a 2RU switch that supports 2.56 Tbps of bandwidth across 48 fixed 1 and 10 Gigabit Ethernet SFP+ ports and four 40-Gbps QSFP+ ports. The 48 ports on the base chassis support 10 Gigabit Ethernet and FCoE. The 4 QSFP ports support 40 Gigabit Ethernet and FCoE.
The Cisco Nexus 56128P also offers two slots for a Generic Expansion Module (GEM). The GEM (Figure 6) for the Cisco Nexus 56128P provides 24 SFP+ ports for 10 Gigabit Ethernet and FCoE or 2-, 4-, and 8-Gbps Fibre Channel, and 2 QSFP+ ports for 40 Gigabit Ethernet and FCoE. The expansion module supports native 40 Gigabit Ethernet on the QSFP+ ports. The GEM is supported on the Cisco Nexus 56128P chassis only and can be populated in either of the two expansion slots.
You need a GEM module for native FC.
Kirk...
Kirk J
Greetings.
Kirk...
Suppose i have a  N56-M24UP2Q  GEM module.
How can it be subdivided in FC interfaces ? per 4, per 8 or per 16 only ?
regards,
GN
