issues with using the output redirection character with newer NXOS versions?
Dinjamin1
Has anyone seen any issues with using the output redirection character with newer NXOS versions?
Am receiving "Error 0x40870004 while copying."
Simply copying a file from bootflash to tftp is ok.
This occurs for both 3CDaemon and Tftpd32 softwares.
Have tried it on multiple switches - same issue.
Any known bugs?
thanks!
The following is an example of bad (NXOS4.1.1b) and good (SANOS3.2.1a)
MDS2# sho ver | inc system
  system:    version 4.1(1b)
  system image file is:    bootflash:///m9200-s2ek9-mz.4.1.1b.bin
  system compile time:     10/7/2008 13:00:00 [10/11/2008 09:52:55]
MDS2# sh int br > tftp://10.73.54.194
Trying to connect to tftp server......
Connection to server Established. Copying Started.....
TFTP put operation failed:Access violation
Error 0x40870004 while copying tftp://10.73.54.194/
MDS2# copy bootflash:cpu_logfile tftp://10.73.54.194
TFTP put operation was successful
MDS2#
ck-ci9216-001# sho ver | inc system
  system:    version 3.2(1a)
  system image file is:    bootflash:/m9200-ek9-mz.3.2.1a.bin
  system compile time:     9/25/2007 18:00:00 [10/06/2007 06:46:51]
ck-ci9216-001# sh int br > tftp://10.73.54.194
Dinjamin1
it's ok i got it - you need to append the text name with newer codes. (works ok without name with 3.x)
MDS1# sh int br > tftp://10.73.54.210
Error 0x40870004 while copying tftp://10.73.54.210/
MDS1# sh int br > tftp://10.73.54.210/shtxt.txt
Please check with new version of TFTPD 32 server. The error may be due to older version of TFPT server, the new version available solved this error. Files are getting uploaded with no issues.
1. Download tftpd32b.zip from:
http://tftpd32.jounin.net/tftpd32_download.html
2. Copy the tftpd32b.zip file into an empty directory and extract it.
3. Copy the file you want to transver into the directory containing tftpd32.exe.
4. Run tftpd32.exe from that directory. The "Base Directory" field should show the path to the directory containing the file you want to transfer.
At this point, the tftpserver is ready to begin serving files. As devices request files, the main tftpd32 window will log the requests.
Best Regards...
