logics_fabric does not exist error massage occured when i connect MDS using FMS 5.0.1a
kimsanghoon
After i connect MDS using FMS 5.0.1a and then when i try to discover MDS, occured error massage "logics_fabric does not exist"
i can't connect MDS
bfeeny
Was it working at some point?  Is there connectivity between the server running FM and the fabric?  You may just delete the fabric and re-discover it, I have not ran into this issue.
