Maximum number of fabric logins
johnnywilhelm
Hi there
I need to provide documented references for a large SAN, and have a few queries.
I have the show tech-supports for an edge-core-edge SAN consisting of 2 redundant fabrics.
There are 4 host edges, 1 core, 4 storage edges per fabric. All are MDS 9500 series directors, running SAN-OS 3.2.2a.
In the Large SAN Design Best Practices whitepaper
(http://www.cisco.com/en/US/prod/collateral/ps4159/ps6409/ps5990/white_paper_C11-515630.pdf)
there is a reference to the maximum number of fabric logins.
"The Cisco MDS Family supports up to 10,000 fabric logins in a physical fabric, regardless of the number of VSANs in the network."
1) Is this specifically refering to the number of f_ports?
2) If not, what is the 10,000 referring to?
In the Cisco MDS NX-OS Release 5.0 Configuration Limits
(http://www.cisco.com/en/US/docs/switches/datacenter/mds9000/sw/5_0/configuration/guides/limits/limits_50.html)
there is a mention of 10000 FCNS entries per fabric.
This is the only reference I can find that correlates the two limits.
The Configuration Limits for Cisco MDS SAN-OS Release 3.x
(http://www.cisco.com/en/US/products/ps5989/prod_troubleshooting_guide_chapter09186a0080679fd4.html)
makes no mention of FCNS or fabric login limits.
3) Is the reference to 10000 FCNS entries (in the NX-OS 5 limits) also the number of fabric logins?
In the show tech-support, there is a command
`show tech-support fcns`
`show fcns database vsan 1-4093`
VSAN 431:
FCID        TYPE  PWWN                    (VENDOR)        FC4-TYPE:FEATURE
0x050002    N     50:06:04:8c:52:a6:c0:69 (EMC)           scsi-fcp 253
0x050003    N     50:06:04:84:52:a6:c0:49 (EMC)           scsi-fcp:both 253
0x050004    N     50:06:04:8c:52:a6:c0:49 (EMC)           scsi-fcp 25
<.. output abbreviated for brevity>>
Total number of entries = 1066
4) Does this mean that there are 1066 fabric logins?
When I look further in to it, and see the command
`show fcns database detail vsan 1-4093`
VSAN:431   FCID:0x0500b1
port-wwn (vendor)           :10:00:00:00:c9:72:4d:9c (Emulex)
                             [nus157_hba0_0]
node-wwn                    :20:00:00:00:c9:72:4d:9c
class                       :3
node-ip-addr                :0.0.0.0
ipa                         :ff ff ff ff ff ff ff ff
fc4-types:fc4_features      :ipfc scsi-fcp
symbolic-port-name          :
symbolic-node-name          :Emulex LPe11002-S FV2.82a4 DV2.50o
port-type                   :N
port-ip-addr                :0.0.0.0
fabric-port-wwn             :21:07:00:0d:ec:3a:44:c0
hard-addr                   :0x000000
permanent-port-wwn (vendor) :10:00:00:00:c9:72:4d:9c (Emulex)
It shows that most of the entries have the port-type: N.
5) Does this mean they are N_ports, not F_ports?
I would really appreaciate answers to these questions.
setmason
John,
Cisco NXOS Configuration Limits (reference/background link)
     Answer: Yes, the 10k logins in the Design Guide Whitepaper refer to the number of Fabric logins, not the number of physical ports.  This is because you could have a single F_Port that has multiple logins as part of it.  For example, an Nexus 5000 in NPV mode could connect to a MDS 9513 via one F_port (NP_Port on the Nexus 5k), but have many Fabric Logins (technically, one FLOGI and multiple FDISC).
     Answer: Number of devices logged into the Fabric not the number of ports in the fabric.
     Answer: Yes, since every device out there that FLOGIs into the fabric registers with the nameserver.
4) In the below output does this mean that there are 1066 fabric logins?
VSAN 431:
Answer: Yes.
                             [nus157_hba0_0]
class                       :3
port-type                   :N
hard-addr                   :0x000000
Answer: An N_Port is an end device like a storage port or an HBA, which connects to an F_Port (Fabric Port) which is the corresponding port on the switch.  This is why you see it as an port-type of N, rather than NL (Node Loop) F, E, or FL (Fabric Loop), as only N or NL can represent the end device itself and not the port on the switch.
Hope this helps,
Seth
setmason
John,
VSAN 431:
Answer: Yes.
                             [nus157_hba0_0]
class                       :3
port-type                   :N
hard-addr                   :0x000000
Hope this helps,
Seth
Thanks for the comprehensive answer Seth!
