MDS 9124 Performance
bryceallard
Visitor
I've been monitoring the performance of my MDS 9124 FC switch and have some concerns. The transmission rates are peaking at over 700 MB/s when the port is only rated at 400 MB/s on the 4Gb switch. Is this normal or does it indicate a problem?
6 Replies 6
Michael Brown
That doesn't sound right to me....on a single port, the through put should max at 400MB. You not looking at a port-channel by any chance are you? Sounds like it might be reporting a combination of 350MB ingress and 350MB egress.
bryceallard
Visitor
Attached is an excel speadsheet with data collected from the Fabric Manager performance monitor.
sidbartle
Community Member
Check to see if the counters are in 64bit, I have seen 32 bit counter wrap to graph the data and give readings like this.
From memory the mrtg cfg file needed to have something like this
Target[10.50.45.34_fc1_1]: #fc1/1:public@10.50.45.34:::::2
by default I the configuration file had
I would suggest opening a case with Cisco TAC, or your MDS support provider and request it be investigated. I believe it's cosmetic...and I would use the command line to monitor the situation.
marsnow
Community Member
Excluding FM out of the equation what performance do you see from CLI?
Use
sh int fcx/x count br
If this also shows 700MB/s then it is a SAN OS issue not FM.
sunyu
Community Member
400MB/S is just a average value in 5min .
