09-03-2014 11:12 AM
4 MDS 9124 switches rebooting with the same strange behavior. The problem occurs if we have instability (e.g. spanning-tree calculation problems) on the LAN where the management interfaces are connected.
ciscomds11# show version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2009, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
BIOS: version 1.0.16
loader: version N/A
kickstart: version 4.2(3)
system: version 4.2(3)
BIOS compile time: 10/23/08
kickstart image file is: bootflash:/m9100-s2ek9-kickstart-mz.4.2.3.bin
kickstart compile time: 10/26/2009 0:00:00 [12/05/2009 05:47:54]
system image file is: bootflash:/m9100-s2ek9-mz.4.2.3.bin
system compile time: 10/26/2009 0:00:00 [12/05/2009 07:07:26]
Hardware
cisco MDS 9124 (1 Slot) Chassis ("1/2/4 Gbps FC/Supervisor-2")
Motorola, e500 with 516136 kB of memory.
Processor Board ID JAF1223ASFS
Device name: ciscomds11
bootflash: 254464 kB
Kernel uptime is 0 day(s), 22 hour(s), 39 minute(s), 49 second(s)
Last reset at 569578 usecs after Mon Sep 1 12:25:37 2014
Reason: Reset triggered due to HA policy of Reset
System version: 4.2(3)
Service: sysmgr stateful recovery
ciscomds11#
Can anyone please help? Thanks
Luis Policarpo
09-04-2014 09:38 PM
When was the last time the MDS was rebooted? I remember an old bug that reboots devices after 700+ days up (fixed already) and that might be causing the issue here...
-Kenny
09-05-2014 01:26 AM
Hi Kenny,
thats not the issue. The customer made a change on a switch that provoked a major problem on the spanning-tree calculation in the network. After that ALL 4 MDSs rebooted simultaneously with the same reason.
I think the problem is related with this bug: https://tools.cisco.com/bugsearch/bug/CSCTJ68614.
Thanks.
Luis
09-09-2014 03:59 AM
upgraded to software version 4.2(9) and problem solved.
Luis
