MDS 9124 san switch, need to enable NPIV
I'm very new in Cisco MDS 9124 san switch.
Can some one help me to understand this swicth like how to create zone, alise, zone config. (I hv experince in Brocade SAN switches).
Also how to enable the NPIV in this switch? if I will enable the npiv, what persecution I need to be take care prior?
Thanks in advance ...
Bhupendra
5 Replies 5
Walter Dey
Hi Bhupendra
see eg
http://www.gkhan.in/how-to-create-zone-and-activate-zoneset-cisco-mds-switch/
https://www.youtube.com/watch?v=yktQ6xvRfvg
Although I would recommend to use device alias, not FC alias
https://www.cisco.com/en/US/docs/storage/san_switches/mds9000/sw/rel_3_x/configuration/guides/cli_3_4_x/ddas.pdf
To enable or disable NPIV on the switch, follow these steps:
Command
Purpose
Step 1
switch# config t
Enters configuration mode.
Step 2
switch(config)# feature npiv
Enables NPIV for all VSANs on the switch.
Step 3
switch(config)# no feature npiv
Disables (default) NPIV on the switch.
Thanks Walter for your valuable comment.
if I will enable the npiv then what persecution I need to be take care prior?
Hi Bhupendra
You can enable NPIV anytime !
The command is global and non disruptive.
Walter.
Mordechay Amir
For enabling NPIV you might need to use this command: "npiv enable"...
It depands on the nx-os you run.
Thanks Amir :)
