MDS 9134 Basic Config
themasher
Community Member
Hello, I have 2 new MDS 9134 switches. I have connected them using the 10 gb ports. Port 33 on one to port 33 on the other and port 34 on one to port 34 on the other. The device manager still shows down. Do I have to configure these? If so can anyone explain the process or point me to a user guide.
17 Replies 17
inch
Level 7
Level 7
G'day,
You will need to configure the ports to enable ISL traffic to flow over them. These ports are called "E" ports or you can have a trunking "E" port which will carry more than one VSAN (Virtual Storage Area Network) over the link.
If this is your first time diving into fibre or storage networking in general there are some fundamental design rules which need to be covered of before you start.
You really should be using dual switching fabrics. This can be done using your two switches and using vsan 99 on one switch and vsan 100 on the other.
You can still connect these switch for administration purposes but put the two E ports on vsan 88.
You can also trunk vsan 99 and vsan 100 over the ports but you must setup your fcdomain properties (domain id and priority).
There is some basic documentation on the cisco website but now with the wiki available I hope that will improve soon.
I can recommend the storage area network book by Tom Clark as a good background read on fibre channel itself before you release anything to production 🙂
Cheers
Andrew
omer.kanse
Community Member
We have bought for our Storage Network, two (2) MDS 9134 (DS-C9134-K9) with 2 DS-X2-FC10GB-LR ports. But like you can see in the report below, link still down. Waiting for your feedback to fix the problem, thank a lot .
**** MDS in first site *********
OCI-SWCIRP1NBK-01# sh inventory chassis
NAME: "Chassis", DESCR: "MDS UROS 9134 FC (1 Slot) Chassis "
PID: DS-C9134-K9 , VID: V01 , SN: FOX1237HHGX
OCI-SWCIRP1NBK-01# sh int fc1/33
fc1/33 is down (Link failure or not-connected)
Hardware is Fibre Channel, SFP is 10GBASE-LR
Port WWN is 20:21:00:0d:ec:c4:ae:40
Admin port mode is E, trunk mode is on
snmp link state traps are enabled
Port vsan is 1
Receive data field Size is 2112
Beacon is turned off
5 minutes input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
5 minutes output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
1 frames input, 108 bytes
0 discards, 0 errors
0 CRC, 0 unknown class
0 too long, 0 too short
1 frames output, 108 bytes
0 input OLS, 0 LRR, 0 NOS, 0 loop inits
0 output OLS, 0 LRR, 0 NOS, 0 loop inits
Interface last changed at Thu Mar 5 23:31:59 2009
**** MDS on second site *****
OCI-SWLUMNBKE1-01# sh inventory chassis
PID: DS-C9134-K9 , VID: V01 , SN: FOX1238GJJ8
OCI-SWLUMNBKE1-01# sh int fc1/33
Port WWN is 20:21:00:0d:ec:c4:ca:00
Port vsan is 1
1 frames input, 188 bytes
1 frames output, 188 bytes
What is the color of the fiber cable between the 2 ports?
The fibber color is yellow.
We used Single mode with DS-X2-10G-LR= module.
I don't understand why the link can't come up. There is any mystake in my setting?
Config looks good...did you verify that you have the 10G license installed? Also, have you tried a new GBIC or cable? Looks like something physical since both sides show only 1 frame out, and 0 in.
-Mike
Dear Mike,
License has installed on the 2 MDS switches like you can see on the report below. We alo are change DS-X2-FC10G-LR= module without good result.
Tell me, is there any setting we must done for the 10GBASE-LR module, becaus, when I check the speed of the module, I can make changes and I am obliged to use "Auto" (speed are limited to 4 Gbs)
OCI-SWCIRP1NBK-01# sh license
MDS20090227071800940.lic:
SERVER this_host ANY
VENDOR cisco
INCREMENT 10G_PORT_ACTIVATION_PKG cisco 1.0 permanent 2 \
VENDOR_STRING=MDS_SWIFTM9134PL2-10G= \
HOSTID=VDH=FOX1237HHGX \
NOTICE="200902270718009401 \
2901J5741DC" SIGN=65ECE046F830
OCI-SWLUMNBKE1-01# sh license
MDS20090302064602701.lic:
VENDOR cisco
HOSTID=VDH=FOX1238GJJ8 \
NOTICE="200903020646027011 \
2901J5741DC" SIGN=209DFE0299E2
I decided to connect 2 here in the lab to verify there was nothing special needed.
Here are the configs for each end.
pod2-sw4# sh run int fc 1/34
version 3.2(2c)
interface fc1/34
port-license acquire
no shutdown
pod1-9134-35# sh run int fc 1/34
version 4.1(2)
interface fc1/34
no shutdown
What I did run into was that the TX and RX were swapped in the SM cable I used. I had to swap the cables at one end, and when I did that the green port LED came on and the link popped right up.
pod1-9134-35# sh int fc 1/34
fc1/34 is trunking
Port WWN is 20:22:00:0d:ec:51:09:40
Peer port WWN is 20:22:00:0d:ec:51:04:80
Admin port mode is auto, trunk mode is on
Port mode is TE
Port vsan is 1
Speed is 10 Gbps
Rate mode is dedicated
Transmit B2B Credit is 64
pod2-sw4# sh int fc 1/34
fc1/34 is trunking (Not all VSANs UP on the trunk)
Port WWN is 20:22:00:0d:ec:51:04:80
Peer port WWN is 20:22:00:0d:ec:51:09:40
Port mode is TE
Port vsan is 1
Speed is 10 Gbps
Another engineer replaced the SM cable with a MM cable and it seems to continue to keep working.
Perhaps your cable is also reversed and you can get it working by swapping the TX and RX on one end.
Hope this helps,
Mike
Dear Mike,
Our 10 Gbps module X2-10GB-LR with SN:ECL124903JK for one MDS 9134. You can see in the report below that, there is no signal in RX is it normal? can i have the method to enable the module without doing (No shutdown) on the interface?
OCI-SWCIRP1NBK-01# sh int fc1/33 transceiver
fc1/33 sfp is present
Name is CISCO-EXCELIGHT
Manufacturer's part number is SDX4102LR-C1-M
Revision is A
Serial number is ECL1249011J
FC Transceiver Type is X2 Medium
FC Connector Type is SC
Bit Encoding is NRZ
Protocol Type is 10GbE
Standards Compliance Codes :
10GbE Code Byte 0 : 10GBASE-LR
Fiber type Byte 0 : SM, Generic
Fiber type Byte 1 : Unspecified
Transmission Range is 1000 (in 10m increments)
Cisco extended id is Unknown (0x0)
No tx fault, rx loss, no sync exists, diagnostic monitoring type is 0xc7
SFP Diagnostics Information:
Temperature : 27.47 C
Voltage : N/A
Current : 1.38 mA --
Optical tx power : -33.01 dBm --
Optical rx power : N/A dBm --
tx Fault count : 0
Note: ++ high-alarm; + high-warning; -- low-alarm; - low-warning
OCI-SWCIRP1NBK-01#
I would start with checking the other end, does it also see no RX? If so, then the cable may be swapped like I ran into. Swap the RX and TX fibres on 1 end.
If that does not resolve it, swap the SFP between ends (after restoring the cable to how it was) and see if the 'no RX' moves with the SFP. You can also try moving the SFP and cable to port 1/34 to see if the 'no RX' moves with the SFP and cable.
If it moves with the SFP/cable, then the 1/33 port might be defective. If it moves with the SFP/cable, then I would look at the other ends. TX on 1 side should be RX on the other.
- Mike
You are not getting any OLS or LRR increments, this is a bad cable or the Tx and Rx are crossed. On one switch pult the LC connector apart and swap the individual fibres, so left fibre is on the right and right fibre is on the left.
Dear Support,
Please I need your help to know something. I have two (2) 10 GB module (X2-10GB-LR)for interswitches links between two MDS 9134. Could tell me if I can use them like a FC module or not?
Thank a lot for your support
10 GB FC is only for Switch to Switch, so I'm not sure how to answer the questions. Can you use life FC module? Yes if both FC devices are an MDS swtich either 9134 or 95xx with 10 gig module installed.
Those ports can not be configured to support a 10GB FC host or storage array (I don' believe that that are any).
The ports on the MDS can not be made to work like 1/2 or 4 GB FC ports.
Hope this helps,
Mike
Thank Mike, I want to know if Cisco have a module X2-10GB-LR used for interswitches link?
I know that generally, people used DS-X2-FC10GB-LR module, what about X2-10GB-LR?
Best Regards
