12-21-2015 06:30 AM
I have a MDS 9148s configured with NPIV, all my ports are connected to EMC, my question is,, one of the ports is set in FL mode automatically.
And I don’t understand why this is happening?
Thanks. all
12-21-2015 06:40 AM
what's connected to that port, tape drive/library ?
12-21-2015 12:02 PM
as dynamoxxx mentions, tapelibraries still have some default behaviour of NL ports; however, it should be possible to force them to N port.
12-22-2015 05:34 AM
Sorry for the delay, I have an EMC device, I’m trying to find out exactly what is ,as dynamoxxx, asked, but the strange thing is that I have the same devices connected to other ports, and all the ports are in F mode.
Thanks!
12-22-2015 05:44 AM
Hi Juraj
Did you try to fix this MDS port to F (instead of FL), and see if the end device can handle it.
Walter.
12-22-2015 05:51 AM
Hi Walter,
No, I did not do that test, you will mean to force type the port? right?
Thanks. !
12-22-2015 05:59 AM
Yes, I mean not auto negogiation the port type, but set it fix to F. If it doesn't work, it means that this end device does only support NL !
12-22-2015 06:20 AM
I will change that in a few more minutes and send you an update.
Thanks in advance !!
