MDS 9220i FCIP TCP Connections
Brunello
How many TCP connections (2 or 5) should be set on MDS 9220i with min=1100 and max=1250 Mbps? I'm thinking 2, but I want to be sure.
Thank you
Bhavin Yadav
Here you go (Using 10GE interface):
* To achieve improved throughput (10G mode)
* Set max TCP bandwidth to 10000 and min bandwidth to 9000
* Create 4 FCIP tunnels per IPStorage port
* Configure 5 TCP connections on each FCIP tunnel
* Configure MTU to 2500 bytes on the IPStorage port
* Enable compression when IPSec is enabled
* Recommended FCIP configuration (1G mode)
* Create a minimum 1 FCIP tunnel on each IPStorage port
* Configure two TCP connections for each FCIP interface
* Set the MTU size as 2500 for both IPStorage ports
