Showing results forĀ
Search instead forĀ
Did you mean:Ā
MDS 9396s port groups per ASIC
Hello!
Can anybody suggest a command (or exact info) which shows what port groups on MDS 9396s belongs to which ASIC (i.e. for example are the ports fc1/1-8 served by ASIC 1, ports fc1/9-16 served by ASIC 2 etc., or in some another ways)?
I mean a commands which can produce a similar output as, for example, show platform pm if-numbers on Nexus switches...
I've tried to use commands like  show port-resources module 1  and  show port-resources internal info, but there is only an information about ASICs quantity and type (12 FC ASICs), port groups identity etc., but there is no necessary info (about exact port-to-ASIC mapping)...
Thanks in advance!
cassiolange
Hello Aleksey,
Cisco live - BRKSAN-2883.
cassiolange
Hello Aleksey,
Thanks, cassiolange!
This is exactly what I wanted to find out! Because I can not found anything like this in current available documentation for 9396... :)
Thank you very much!
