MDS-9513 error message DAEMON-2-SYSTEM_MSG: fatal: Write failed:
Peter Mullaney
Hello all,
I was hoping someone out there might have seen this error before that I'm seeing on my switch running at 4.2(3).
In the show logging log:
2013 Jun 27 10:58:43 dldn0804psw %DAEMON-2-SYSTEM_MSG: fatal: Write failed: Connection reset by peer length of packet causing error 136 136  - sshd[19771]
I cannot find an explination for the cause of this alert or what the implications are.
Any input would be much appreciated.
Peter
Peter Mullaney
CSCta10776.
Peter,
would you please post content of that bug report ?
Thank you
@dynamoxxx
@dynamoxxx
Peter Mullaney
the bug I have mentioned is for Product Nexus 7000 and not MDS but the errors are almost exact
CSCta10776 Bug Details
Status
Status
Fixed
(Resolved)
Severity Severity
3 - moderate
Last Modified Last Modified
In Last Year
Product Product
Cisco Nexus 7000 Series Switches
Technology Technology
1st Found-In 1st Found-in
4.1(4)
Fixed-In Fixed-in
4.2(1)
5.0(0.153)
5.0(0.156)
5.0(1)
4.2(0.247)
4.2(1)N1(1)
Component(s) Component
security
Syslog message displayed when sshd session to NXOS platform is abruptly
interrupted and NXOS fails to record the IP address for the syslog function.
Symptom:
%DAEMON-2-SYSTEM_MSG: fatal: Write failed: Broken pipe length of packet causing
error 140 140 - sshd[14913]
Workaround(s):
None at this time. The log message is not indicative of any known serious issue.
My MDS is running at NX-OS 4.2(3)
I
