MDS command line 'show module' output
david.marsh1
Community Member
On the 'show module' output (as shown below), is the bandwidth the actual connection speed? Or is it the speed that has been manually set for the port?
Port-Group 1
  Total bandwidth is 32.4 Gbps
  Total shared bandwidth is 32.4 Gbps
  Allocated dedicated bandwidth is 0.0 Gbps
  Interfaces in the Port-Group       B2B Credit  Bandwidth  Rate Mode
                                        Buffers     (Gbps)
  fc1/1                                      32        2.0  shared
  fc1/2                                      32        2.0  shared
  fc1/3                                      32        2.0  shared
  fc1/4                                      32        2.0  shared
  fc1/5                                      32        2.0  shared
  fc1/6                                      32        4.0  shared
dakester
Hi David,
The command is
show port-resources module x
It's the amount of bandwidth reserved for shared/oversubscribed interfaces.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/sw/6_2/configuration/guides/interfaces/nx-os/cli_interfaces/gen2.html#48591
It can be modified using the interface commands,
swithport speed
or
switchport speed auto max
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/sw/6_2/configuration/guides/interfaces/nx-os/cli_interfaces/gen2.html#30323
David
dakester
Hi David,
The command is
swithport speed
or
David
Thank you.
