MDS FC Blade Switch for IBM - Licensing
schuetzm
our customer has got installed the 20-port-switch of the "Cisco MDS Fibre Channel Blade Switch for IBM BladeCenter". He wants to change some of the links now. For that reason he asked me:
- Is there a fix relationship between a port and a license?
- Can we use any port as long as we fall below the number of licenses?
Thanks in advance and regards
Matthias
emcprateek_2
Hello Matthias,
Cisco Fabric Switch for IBM BladeCenter (20 ports; 14 internal 2/4 Gbps, and 6 external full-rate ports) licenses for internal ports are allocated as the ports come up. Licenses for external ports are allocated sequentially.
Refer "On-Demand Port Licensing" section on CLI guide here :
http://www.cisco.com/en/US/docs/storage/san_switches/mds9000/sw/rel_3_x/configuration/guides/cli_3_3/ondport.html
Customer can select the specific external ports he wants licensed.
switch# config t
switch(config)# interface fc1/1
switch(config-if)#port-license acquire
Prateek
