MDS-Nexus SAN design guide and MDS software
gwhuang5398
Level 2
Level 2
Is there a design guide for MDS 9500 working with Nexus switches?
Is MDS usually equipped with both SAN-OS and NX-OS software so you can choose to configure MDS in SAN-OS or NX-OS? or SAN-OS and NX-OS means the same for MDS?
fb_webuser
Level 6
Level 6
MDS Switches are all running NX-OS as well. This makes the integration between MDS and Nexus really easy and seamless. There are a number of design guides available, depending if you want FC, FCoE or any combination.
Posted by WebUser Adriaan Steyn from Cisco Support Community App
Do you have the links to the design guides? I was not able to find from Cisco site.
I would think FC between Nexus and MDS, and FCoE between Nexus and Nexus.
