MDS Phantom Device Alias and PWWN results
emperor1431
I am getting some odd results when zoning currently and was looking for feedback!
So just an example.  Here is a new zone I wanna put in.
zone name ESXUCSD10-VPLEX-E1-B0-FE03 vsan 102
member device-alias ESXUCSD10
member device-alias VPLEX-E1-B0-FE03
But when I look at that same zone that was just created...
sh zone name ESXUCSD10-VPLEX-E1-B0-FE03 vsan 102
  pwwn 20:00:00:25:b5:2d:b0:09 [ESXUCSD9] < -WTF?
  pwwn 50:00:14:42:b0:60:2a:03 [VPLEX-E1-B0-FE03]
Where did the D9 blade come from?
Different WWN names in the aliases!
 sh device-alias database | inc ESXUCSD10
device-alias name ESXUCSD10 pwwn 20:00:00:25:b5:2d:b0:0a
 sh device-alias database | inc ESXUCSD9
device-alias name ESXUCSD9 pwwn 20:00:00:25:b5:2d:b0:09
Device alias database has the correct PWWN for D9 and D10 blades but it is pulling this from somewhere. I have searched the configs on both switches in the fabric - everything matches up as it should except this example.
Thoughts?
Thank you!
dakester
Try these commands:
show device-alias database | i 20:00:00:25:b5:2d:b0:09|ESXUCSD9|ESXUCSD10|20:00:00:25:b5:2d:b0:0a|Total
show zone internal ddas-table | i 20:00:00:25:b5:2d:b0:09|ESXUCSD9|ESXUCSD10|20:00:00:25:b5:2d:b0:0a|Total
Might be this bug.
CSCua02159 Dev's zoned by device-alias don't work after port flap or zone activate
There is a new command in the Resolution Summary you can try.  It does not provide output, so re-issue the above commands if needed.
zone internal ddas-table cleanup duplicate-entries
We are at version 6.2(11b) I think we are past that bug?
Thanks!
