MDS9124e password recovery and NXOS recovery process ?
jjpeyrache
hi
what is the process in order to do password recovery on MDS9124e since there are console port ?
same question for NXOS recovery ?
thanks for any help
JYP
stephen2615
Level 3
Level 3
The HP site explains how to do password recovery for the 9124e.
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00897189/c00897189.pdf
The console port is a psuedo serial port in the interconnect bay. That document explains it all.
I am not sure what you mean by NXOS recovery.. Are you talking about password recovery for all switches or something else?
Stephen
hello
thanks for your pointer, i asked for NXOS
recovery when 9124 boot and go in
boot> prompt instead normal boot
thanks
JYP
