Meshing a 9216 and a McData Switch
kegelbrian
I am adding a 9216 to a McData fabric. The current McData switch is softzoned, but I will be working offline so all zoning will be disabled. I read the white paper and the only thing that reallly jumped out was making sure the domain id was in a proper range.
Outside of making sure the domain id is within range ~100. What other issues are there about meshing the two networks? Will I be able to start creating VSANs immediatly or do I need to make further changes. Are there any firmware incompatibility issue (both will be upgraded to the latest revision)? Are there bumps I need to know before I do this outside of what was in the white paper.
Thanks for any and all help/advice!
tblancha
Actually, the domain IDs for the vsan that is in interop4 mode should be in the 1-31 range and not conflicting with the MCDatas. Zoning must be done by domain,port or PWWN. Here are some concepts.
* The SWWN of the Cisco switch's vsan must be modified to include the McData OUI
* The domain ID's that exist in the fabric (McData & Cisco) must be in the range of 1-31
* The FCID's will actually be in the 96-127 range. This is because the domain ID's are seen as 1-31 but actually have a base of 96. So, the domain ID is really 96+domain_ID but seen as just domain
* FC4 features are not distributed
* PWWN and/or domain,port based zoning is supported
* Default zoning policy changes are distributed
* If the mode4 VSAN is in the IVR topology, then the virtual domains will be in the range of 96-127
Suspend the vsan and configure the OUI to be in the 08:00:88.
MDS-9216a(config)# vsan data
MDS-9216a(config-vsan-db)# vsan 100 suspend
MDS-9216a(config-vsan-db)# vsan 100 interop 4
MDS-9216a(config-vsan-db)# vsan 100 interface fc1/1 - 2
MDS-9216a(config-vsan-db)# exit
MDS-9216a(config)# wwn vsan 100 vsan-wwn 20:64:08:00:88:0d:5f:81
Verify the VSAN 100 SWWN is using the 08:00:88 OUI
MDS-9216a(config)# do show wwn all-user-configured
vsan wwn configured by user
100 20:64:08:00:88:0d:5f:81
Un-suspend the VSAN and check status
MDS-9216a(config-vsan-db)# no vsan 100 suspend
MDS-9216a(config-vsan-db)# do show vsan 100
vsan 100 information
name:VSAN0100 state:active
interoperability mode:4
loadbalancing:src-id/dst-id/oxid
operational state:up
