Module DS-X9148
ua.kyivstar
Module FC DS-X9148 power cycled by supervisor time to time. Error Message in syslog:
Module 2 reported status for component 88 code 0x40240015
Module 2 (serial: JAB102600QN) reported failure on ports 2/1
-2/48 (Fibre Channel) due to Fatal runtime Arb error. (DevEr
r is bitmap of failed modules) in device 88 (device error 0x
2).
Any suggestions without call to support (i've done it)?
inch
Level 3
Level 3
G'day,
Have you enabled any debugging information on the linecard itself?
Cheers
Andrew
tblancha
An arb error sounds like the failure is occuring in hardware. I would ask tech support for a RMA. How often does this error occur?
