Multi AS configure
shivccna_2011
Hello All
Please confirm can we configure multi AS on cisco 2811 Router How can it possible
5 Replies 5
Philip D'Ath
Assuming we are talking about BGP here, use the local-as feature.
http://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/13761-39.html
Hello Mr. P. dath,
As you didn't  understand my exact requirement  Currently i have two AS like, AS-10385,48174 and So Pleas confirm how we can configure both as AS-10385,48174
Please find the attached network diagrma and suggest for the  same
You can use the local-as feature I posted the link to above.
Hello Mr. P. dath,
As you suggested in above link according to this we can configure only one AS on Cisco 2811 Router.
But we want to configure both AS on cisco 2811 Router.
Let me present a more comprehensive example.
First choose one AS to be your primary.
router bgp 10385
Now add some neighbour lines to present yourself as a different AS when taking to the other ISP.
  neighbour x.x.x.x local-as 48174
This is the only way to make a single router appear to look like two (or more) different AS systems.
