MDS 9513 - 48 Port module with Bootflash "Suspended" state
anand.gopinath1
Hi Team
We have one module in our Cisco MDS9513 director as below with bootflash state "suspended"
Module  ; DS-X9248-96k9
Switch MDS 9513 ( 13 Slot )
Firmware : 5.0(4b )
Is there any online way to change the bootflash status back to "running  " without reseating the module  ??
Appreciate your quick response in this regard
Test                    Frequency       Status          Action
Bootflash                10 Sec         Suspended       Enabled
EOBC                      5 Sec         Running         Enabled
Loopback                  5 Sec         Running         Enabled
Tcam                      1 Day         Running         Enabled
jihicks
Hi Anand,
This is an indication that bootflash has failed on the line card and the line card should be replaced.
If the line card is up now and you reseat/reload it, I would expect the next state to be "powered down" because the line card can not load the firmware.   You should leave it as is until you can get it replaced.
Best regards,
Jim
jihicks
Hi Anand,
Best regards,
Jim
