Multihop FCoE question
krun_shah
is it possible to bind a portchannel carrying multiple fcoe vlan to more than one vfc in diff vsan?
Lets  say with one N5K connected to N7K using a eth-portchannel carrying FCoE vlans 100(vsan 100) and 200 (vsan 200). Is it possible to configure two vfc  interfaces in vsan 100 and 200 respectively on each switch? That way one  link failure in port-channel bundle will not cause the whole SAN fabric  to be down and hashes FCoE traffic to available port.
There is no vFC port channel, the way the N7K and MDS do FCoE is slightly different from the 5K.
On the 7K/MDS, you create a regular port channel. example:
!Command: show running-config interface port-channel22 membership
!Time: Tue May  1 09:54:35 2012
version 5.2(4)
  switchport
  switchport mode trunk
  switchport trunk allowed vlan 200
interface Ethernet7/22
  channel-group 22 mode active
  no shutdown
interface Ethernet7/23
  no shutdown
Now to trunk VSANs over this, you need to allow the vlan mapped to the vsan and configure the following:
N7K-24-12-7010-1-fcoe# show run int vfc-port-channel 22
!Command: show running-config interface vfc-po22
!Time: Tue May  1 09:56:40 2012
version 5.2(4)
interface vfc-po22
  bind interface port-channel22
  switchport mode E
  switchport trunk allowed vsan 200
  no shutdown
The MDS and 7K map the vfc-port-channel to the port-channel automatically as long as you are using the same number.
On the 5K, you would create a vFC and bind it to a port-channel.
Does this answer your questions?
13 Replies 13
vdsudame
i dont think there is a need to have multiple vfcs on n5k/n7k and dont believe we can do this either. the vfc will go down only when all the ports in the port channel go down. until that point the vfc is going to stay up. also you can implement "port channel load balance source-dest-port" for lacp po so as to have all the links in port channel utilized uniformly. by default we use single link only with source dest.
Vin.
Sorry If I confused anyone. What I mean is one vfc in vsan 100 and one vfc in vsan 200. Both vfc has bind itnerface po 10 command under it as well as port chanenl 10 is trunking FCOE vlans 100 and 200. Is this config possible?
we cannot bind one physica or port channel interface in multiple vfcs.
krun_shah
unfortunatly this is not documented on nexus 5000 and/or 7000 configuration guides.
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/fcoe/513_n1_1/b_Cisco_n5k_fcoe_config_gd_re_513_n1_1_chapter_0100.html#task_12735881956
http://www.cisco.com/en/US/partner/docs/switches/datacenter/sw/nx-os/fcoe/configuration_guide/b_Cisco_NX-OS_FCoE_Configuration_Guide_chapter_0100.html#task_12735881956
Conceptually it should be possible, I do not have lab equipment to test so just want to know what is technical reason behind it.
feature fcoe
vsan database
vsan 100 name Fabric-A
vsan 200 name Fabric-B
vlan 100
fcoe vsan 100
vlan 200
fcoe vsan 200
int eth 1/1-2
channe-group 10 mode active
int po 10
switchport trunk allowed vlan 1,100,200
int vfc 1
  switchport mode E
  bind interface po 10
int vfc 2
  switchport mode E
vsan database
vsan 100 interface vfc 1
vsan 200 interface vfc 2
at fiber channel level when a device logs in or does a flogi (fabric login) it gets a unique wwn (which is analogous to a mac address in ethernet world). we cannot have that same unique wwn log in on two different ports on a nexus switch at the same time. For this same reason you cannot bind same port channel in two different vfcs as we cannot have a fabric login with the same wwn across two different vfcs.
Krun,
I think what you are trying to achieve is dedicating one vFC per vsan. This is possible but instead of creating a port-channel with two links and binding two vFCs to it, you would have to create two SINGLE link port channels. Once you have two port channels, you can bind ONE vFC to each.
By doing this, you lose 'link level redundancy' which you would have had by using a port channel with multiple physical  interfaces.
Now if you determine you want link level redundancy, you have to create a two interface port channel. This port channel will be between two different Cisco switches so from a Fiber Channel perspective, this will automatically be a Trunking E port. This port channel, which is a "virtual link" since you are combining multiple interfaces into one logical link will have to follow the same rules any single interface follows, which is ONE TE (Trunking Expansion) port.
Do you mean, combining multiple vfc interfaces in to a single vfc-port-channel ?? This is only possible in N7K.
Further more, it is not possible to VSAN trunking on vfc or vfc-portchannel interfaces....This is clearly documented in config guide.
I can do something like following
int vfc 1
bind interface eth1/1
channel-group 10
int vfc 2
bind interface eth1/2
channel-group 10
int vfc-port-channel 10
But above vfc-port-channel can only be E or F port not trunk carrying multiple vsans.
Can you provide a link to the documentation + page number? Here is an example of what I mean:
  • vFC-Port-channel on N7K
7010-1-fcoe# show int vfc-port-channel 20
vfc-po20 is trunking
    Bound interface is port-channel20
    Hardware is Ethernet
    Port WWN is 25:25:00:22:55:79:66:00
    Admin port mode is E, trunk mode is on
    snmp link state traps are enabled
    Port mode is TE
    Port vsan is 1
    Speed is 20 Gbps
    Trunk vsans (admin allowed and active) (200,3011)
   Trunk vsans (up)                       (200,3011)
    Trunk vsans (isolated)                 ()
    Trunk vsans (initializing)             ()
vfc-po20
    304630 fcoe in packets
    52662280 fcoe in octets
    304747 fcoe out packets
    23547260 fcoe out octets
    Interface last changed at Fri Apr 27 16:04:17 2012
  • Running config:
!Command: show running-config interface vfc-po20
!Time: Sat Apr 28 09:54:38 2012
version 5.2(4)
interface vfc-po20
  bind interface port-channel20
  switchport mode E
  switchport trunk allowed vsan add 3011
  no shutdown
  • vFC on the Nexus 5000:
5020-1(config-if)# show int vfc 20
vfc20 is trunking (Not all VSANs UP on the trunk)
    Port WWN is 20:13:00:0d:ec:a3:81:bf
    Port mode is TE
    Port vsan is 1
    Trunk vsans (admin allowed and active) (1,200,3011)
    Trunk vsans (up)                       (200, 3011)
    Trunk vsans (initializing)             (1)
    1 minute input rate 2640 bits/sec, 330 bytes/sec, 3 frames/sec
    1 minute output rate 6928 bits/sec, 866 bytes/sec, 3 frames/sec
      302132 frames input, 23339536 bytes
        0 discards, 0 errors
      302016 frames output, 57040752 bytes
    last clearing of "show interface" counters Fri Apr 27 14:23:37 2012
  • Running config on N5K
!Command: show running-config interface vfc20
!Time: Sat Apr 28 09:56:51 2012
version 5.1(3)N2(1)
interface vfc20
  switchport mode E
  no shutdown
Thanks Carlo that helped a lot.
Terminology is bit confusing because even though you configured switchport mode E under int vfc-port-channel 20, show ocmmand shows TE_port. Normally in MDS world you would configure "switchport trunk mode on|auto" then it becomes a TE_port.
Can you also share config from actual vfc interfaces you bundled in vfc-port-channel? Configuration guide does not show how to bundle vfc interface into vfc-port-channel and confuses a lot. see below
http://www.cisco.com/en/US/partner/docs/switches/datacenter/sw/nx-os/fcoe/configuration_guide/b_Cisco_NX-OS_FCoE_Configuration_Guide_chapter_0100.html#task_8E581CB3695C4748B49157F26DB439F9
Step 3switchport mode                      mode
Example:
switch(config-if)# switchport mode e
Configures the switchport mode for a  virtual Fibre Channel interface. The mode is E or F. The default is F mode.
So I thought vfc interfaces cannot be a trunk ( carrying multiple vsans) ports TE_port it can only be E_port (expanssion port) or F_port.
In nexus 5000 config guide clearly says in limitation you can assign only one vsan per vfc interface and looks like you are managed to trunk multiple vsans on single vfc.
Each vFC interface is                     associated with only one VSAN.
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/fcoe/513_n1_1/b_Cisco_n5k_fcoe_config_gd_re_513_n1_1_chapter_0100.html#con_1288667
on n7k this is auto bind, ie once you create say regular port channel 10, you have to create the same vfc-port-chanel number 10 and it auto binds the po10 to vfc-port-channel 10 implicitly. As you already know, this is not the same on n5k. on n5k we use the regular 'bind interface po' command to associate the interface vfc with the port channel.
version 5.2(4)
  switchport
  no shutdown
  no shutdown
version 5.2(4)
interface vfc-po22
  switchport mode E
  no shutdown
Wwn? Or fcid i thought wwn are hardcoded in hba
WWN and PWWN are unique and hardcode or burn to HBA. This number is not changeable.
WWN is unique number for HBA
PWWN is unique number for specific port on that HBA
FCID is assigned by the switch when the HBA flogi to fabric
